wheel ?'s
Old Jan 26, 2009 | 12:26 PM
85runnerphx's Avatar
wheel ?'s
what are some good wheels for 85 4runner with 33x12.50r15 pocomp extreme muds? what should the backspacing be? what should the offset be also with no rubbing or no wheel adapter. i have a 3 inch lift by rough country as of right now
Old Jan 26, 2009 | 12:29 PM
904_runner's Avatar
Im running a 12.50 width tire on a 15x8" wheel. No problems. there.
Can't tell you about the backspacing.
Old Jan 26, 2009 | 12:38 PM
well my problem is that my tires are too close to the frame and tie rod so i had to put wheel adapters on to not rub on the tie rod and frame so i am lookin for new rims any suggestions would be great
Old Jan 26, 2009 | 12:42 PM
toyota4x4907's Avatar
People say you're supposed to stay within 4" of width, ie, 10.5" tire on no less than a 6.5" rim..but you can go to 6". If put them on too skinny of wheel, then the center is going to bulge out, on too wide and the center will bulge "in". 15x8 is a good size for 12.5" tires.
Old Jan 26, 2009 | 12:43 PM
backspacing.....
3.5" to 4" perhaps.
Old Jan 26, 2009 | 12:55 PM
but i do have 15x8 rims on now i thinkin about going with 15x10 with a smaller backspacing
Old Jan 26, 2009 | 01:03 PM
904_runner's Avatar
What size backspacing do you have now. Calculate it that way. See how much it is going to take to prevent rubbing
Old Jan 26, 2009 | 01:08 PM
it has 3.750 back spacing with 1.5 wheel adapters
Old Jan 26, 2009 | 01:11 PM
904_runner's Avatar
and it rubs?
Wow i have the same setup and its fine.
by wheel adapters you mean wheel spacers right?
Old Jan 26, 2009 | 01:15 PM
well on your axle its wider if u have the stock one for your year and wheel adapter is where it bolts on to your stock studs than it has studs on itself to push the wheel out farther so it dont rub
kouki420
Sep 2, 2015 11:42 AM
NCRidgeRunner
Aug 13, 2015 04:11 AM
Up&Down
Aug 5, 2015 06:20 AM
Luvmeye22re
Aug 4, 2015 03:53 PM
skoti89
Jul 6, 2015 07:45 PM
