removing pcv baffle in valve cover 22re
starting my 22re overhaul reassembly and having valve cover bead blasted.should i remove baffle under pcv.gasket set came with gasket for the baffle.will screws safely keep it in place.thanks for help
I think you are referring to the flame arrestor baffle under in the valve cover. It also helps drip oil on the cam. It is riveted on. There is nothing to be gained by removing it and then reattaching it with screws. It is hard to clean under it, but really not necessary anyway.
there are 'pins' cast into the valve cover which are then compressed and flattened against the baffle, in much the same way rivets are done. They can be drilled out and tapped for screws to be used to re-attach the baffle to the valve cover.
It's main purpose is to deflect oil mist away from the fresh air inlet, PCV valve and oil fill in order to keep oil from entering the intake (does a good job, no?
Sep 4, 2015 09:27 AM
