Exhaust manifold/muffler bolt stripped
After soaking the exhaust manifold to muffler bolts in PB Blaster, I wound all but one off with ease. The third nut spins but does not back off. Seems the bolt threads are stripped enough that the nut can't catch. Can anyone tell me if the studs on the muffler side of the exhaust manifold are replaceable or are they seated permanently? If permanent, what would you suggest doing to repair the stripped threads?
Bako88, thanks for the insight. The block is a 22R in an 84 2WD truck. From what i could see (low light), the bolt threads were very far gone and would not be enough to re-thread using a tap. If I can get the studs out all will be good and won't need to hunt for a replacement header. Hate to pay $100 when I can just buy a stud or two.
Thanks,
Aaron
Thanks,
Aaron
I my extra manifold off a 1992 would fit on that 22r, you can have it for the cost of shipping.
Otherwise, I think there are tools out there that will grip that stud so you can get it out. Or can you get a pair of ViseGrips or Channel-Locks to it?
see if you can tap a chisel in between the nut and flange as you spin the nut, giving it some incentive to move away from the flange, or tack weld the nut to the stud and see if you can get the stud to back out of the manifold.
Went ahead and took the grinder to the nuts and got the manifold off. Looks like the bolts were stripped and then helicoils were used to repair both. Soaked the studs in PB and have gotten two of the three out. One is holding on tight and will soak over night in the 5 degree air. If I can't get it to loosen in the morning with a vise, I will cut it off and drill it out, tap it and be done with it. Thanks Bako88 for the offer. Sometimes I just refuse to give up!
Abe, good evening! Hope you are staying warm. Before grinding off the nuts, I tried what you suggest. Used a prybar to push up on the nut hoping it would catch a thread. No luck and worried about fractures in the manifold or muffler. Hate to add to my problems. Have to remember the tack weld suggestion, however. A Miller MIG welder is something I am considering as a next big purchase.
pyramid
Jul 30, 2015 10:05 AM
