Vibration problem solved..thanks!
Old Dec 31, 2008 | 11:23 AM
clinchguide's Avatar
Got a 94 runner that has had a driveline vibration problem since I've had it (about 6 weeks). Between 40 and 6o miles per hour it would vibrate, you could feel it most around the shifter. U joints seemed ok. Took to a couple of places and was told tires needed balanced. Still had the vibration. I could feel it in the driveline. Found this board, researched the problem and was led to the locknut on the output shaft of the transfer case, under the companion flange. Dropped the driveshaft and sure enough the nut was barely finger tight. Cranked it down, restaked the nut and voila! No more vibration. Thanks yotatech! Awesome resource of information. If anyone else has this problem it's easy to get to and quick to check. Thanks again board members.
Old Dec 31, 2008 | 02:03 PM
ahickman's Avatar
Clinchguide, good to hear that you found the culprit. I am still trying to narrow down mine ( https://www.yotatech.com/forums/f116...r-hour-162275/). The companion flange would be one of the few things I have not considered. Do you have a manual or auto?
Old Dec 31, 2008 | 02:25 PM
Bigblock's Avatar
Got his nut and left I guess.
Bigblock
Old Dec 31, 2008 | 03:34 PM
ahickman's Avatar
Hah! Excellent....do you blame him?
Old Dec 31, 2008 | 05:26 PM
dbcx's Avatar
Bigblock
and quik to
Old Dec 31, 2008 | 06:29 PM
Haha..sorry, had to run out. It's an auto tranny.
SubiKing
Aug 21, 2021 03:57 AM
theking11863
Mar 19, 2016 09:36 PM
Logz808
Jul 26, 2015 07:09 AM
Jonny246
Jul 24, 2015 12:37 PM
kyletbert
Jul 17, 2015 11:39 AM
