LC Engineering Turbo motor...disappointment??
I was watching a video of a dyno run...it was posted in one of the forums... The beginning in the video it displays what is done to the truck, in which it says turbo LC Engineering engine...long story short, at the end, it says "197hp, 237 (i think) torque...
Now, I've been looking into the turbo LC engine...it's around $6K...but if it only put 197hp to the wheels, I'll opt to build my own. For a turbo motor, I don't care if its only 4cyl, paying $6K for less than 200hp seems horrible. Are these motors really only putting out 200?
damn I spent 6K on my B-Series honda engine and that thing's built to handle 450hp. Only running 300 right now though.
Sounds like a waste of money, the LCE engine. Do a 1UZ swap
I'd like to do that one day...when I have money...lol
I don't know anyone who's offered a cheap way to get mega-horsepower from a 22re. There's some cheating available, but once you pop over around 120 hp from a 22re, the cost escalates dramatically. Best I've seen is about $1000 per 20 hp... and all of it comes with reduced reliablility.
Put it this way, LCE is top of the line. They build 4 cylinders for racing. You get what you pay for, $6k gets you 197hp at the wheels and a bulletproof motor. I would not want a turbo motor on a rock crawler though. More desert racing, long travel, circle track. Most motors/turbos don't boost until about 2500 rpms unless its a tiny turbo. You have to keep the engine up to speed to get the power.
But then maybe too much torque at low rpm's won't work with low gear ratios, making a turbo more suitable for a dual-purpose crawler/street engine.
Many variables to consider....
as far as I can figure, for the cost to build a good decent aftermarket forced induction setup on the 22re, you could put together a naturally aspirated motor with a bulletproof bottom end that'll probably have more HP and toque, as well as a steady curve on the two through the RPMs...
on the 22re anyway; that's not going to apply to every motor...
don't get me wrong, you can boost the $#!@ outta a 22re and get some good power, BUT, you'll have to modify litterally everything to make the motor handle the boost...
I will counter that a bit though and suggest that the turbo could be lost and replaced with a supercharger without significant detriment. The engine management system LC offers for use with their turbo works equally as well with a supercharger. You'd then have a low-end-torque engine suitable for crawling....
Bottom line I love LCE and their products. Wish I could afford them all.
LC is very pricey. We can build a motor for 3k and they will charge 6k or more for it. So if your willing to do your homework you could get a nice FI set up for around 3k.
Also 190+ hp out of a 4 banger is pretty damn good. Thats near double the hp.
The whole cost / hp ratio is what I was getting at... you can add 25 or so hp to a stock 22re for about 1000 total (considering the cost of totally rebuilding the engine). And then you'll be averaging about 25 hp more for every 1000 dollars you spend on top of that.
I could argue that 190 hp out of a 4 cylinder is not un-heard of and has actually been accomplished many times on stock vehicles during the late 80's through 90's... and often, those mod's, properly worked, could exceed 400 hp at the wheels...
... but that's not the point here.
That's easy to say when you don't have to pony up and prove it...
... scuba ...
... got yer ball joint spacers on yet? How's yer power steering?
Sorry, but what was the last turbo engine you owned?
and before you say it... yes I "F" up too....
... scuba ...
I would look at the 4.7L V8 or 3.4L V6 for a swap, both are capable of ample horsepower with the right modification and you can find both with relative ease for a fraction of the price of the LCE turbo engine.
Had I been able to, I would have bought the 4.7L V8 from the Tundra.
