has anyone done a weber carb conv.?
my 86' 22r is wayyyyyyy too cold natured and likes to stall the second i let my foot off the gas within the first 10 min of starting the engine
i just saw a weber carb conversion on ebay motors for 270ish
i was just curious if these have any results that might be worth the money
"There once was a little button named Search. No one cared to look at him, or to try to even use him to his full potential"
this has been gone over a LOT man...
if you don't want to fork out the $$$ though, what about fixing the stocker?; sounds like the choke's stick'n open a lil, or may not be operating at all...
but the search button does get overlooked too often here...
personally, I'd see if you can fix the stocker...
if not, then consider what you're doing witht he truck; if it's just a DD, then the stocker will do fine for your needs more than likely. The Weber may get better MPG advertised probably, but wait till you stomp on the gas and open up the secondary... your MPG will plumit... at least that's how it was on my Isuzu when I bolted on my Weber 32/36 DGEV... but it was also bored, cammed, ported and polished, so I dunno those may have been a factor too... plus I have a lead foot...
also, check the FSMs in the stickies to get some good stuff about the carb; very good detailed stuff in em!
Toys4parts
Sep 26, 2015 01:56 PM
