manual hub making noise
Old Dec 10, 2008 | 07:14 AM
DupermanDave's Avatar
My front passenger manual locking hub us making a rattling noise above 30 miles per hour. Happens when I coast and give it gas.
Do I need a new hub altogether, or should I just regrease the thing? Could I damage it driving it like this?
Old Dec 10, 2008 | 07:50 AM
DeathCougar's Avatar
Depends on which part has actually failed. The hub seperates from the spindle assembly, so you can take it apart and look inside. You will either find broken parts, or bad bearings in the spindles.
Old Dec 10, 2008 | 08:28 AM
Sounds more like a bad bearing. Why would it go all of a sudden? Wouldnt a bad bearing be a more progressive thing?
I'm going to take it apart this sunday, but until then will it be safe to keep this hub locked? 4wd works fine still, even through the noise.
Old Dec 10, 2008 | 09:58 AM
leebee's Avatar
search for the spindle bushing posts, it will detail what is involved. you can decide how far you want to go with this; ie repack or repair.
lee
dirtoyboy's Avatar
I wouldnt....but then again I dont like buying new hubs either
Old Dec 10, 2008 | 10:05 AM
waskillywabbit's Avatar
Sounds like a driveshaft u-joint.
Old Dec 10, 2008 | 10:29 AM
I was just going to repack the bearing. If that fails I'll just replace it. I found a nice writeup here that explains it really well with pictures included.
Old Dec 10, 2008 | 12:33 PM
just a 22re's Avatar
ok heres the question does it do it only when the hub is locked?
is it fine and normal when the hubs are unlocked?
mine (the trail rig) does this aswell and on mine its the bearings i say jack it up and shack the wheel by grabing the top of it and seeing if it goes in and out of the truck hope it helps you out some what
Old Dec 10, 2008 | 12:53 PM
It only does it while it's locked. And I've narrowed it down to the driver's side wheel only.
So if this is the case...do i need new bearings or just clean and regrease them?
Old Dec 10, 2008 | 12:58 PM
jsn_stockard's Avatar
Depends on how bad. Might just need re packed. Make sure nothing is wrapped up on the cv shaft.
Old Dec 10, 2008 | 01:01 PM
Already checked to see if there was something wrapped around and ctumbling around. There's nothing.
When you say "repack", you mean just pack in some more grease and fill it back up?
Old Dec 10, 2008 | 01:04 PM
yea. Just remember to clean it all out good.
Old Dec 10, 2008 | 01:59 PM
you take the bearings out clean them real good like then go to town with a bearing packer but if they move like my trail rigs does then yeah time for new ones there guy good luck and if they move more then your safe with time to replace them
Old Dec 10, 2008 | 02:24 PM
I'll clean them out, and should the look and feel like they need replaced I will. I'll probably replace them both anyway when I do the piston rings, because the truck will go through some overhauling as soon as spring comes.
razorman8669
Jul 12, 2015 12:13 PM
mlavery85
Jul 12, 2015 10:33 AM
cars-guy
Jul 11, 2015 07:51 PM
Poncho0206
Jul 10, 2015 06:21 PM
ItsJustD
Jul 7, 2015 07:49 AM
