power steering vacuum hoses
Old Nov 26, 2008 | 03:25 PM
supercharged98's Avatar
i recently did an engine swap with a 3.0, i can not rembember for the life of me where the vacuum hoses for the power steering pump go on the intake plenum any help would be outstanding
Old Nov 26, 2008 | 03:37 PM
Tubbyfatty's Avatar
I know there is a sticker under the hood for vac lines, like where they go and how they go lol.....idk if that helps you, and the p/s has vac lines?
Old Nov 26, 2008 | 04:12 PM
but it only shows one hose not two
Old Nov 26, 2008 | 04:51 PM
Tubbyfatty's Avatar
Well i have no idea what you are talking about lol. Sorry man, im sure someone on here will help you out.
Old Nov 26, 2008 | 09:34 PM
anotherjeff's Avatar
They both go the the plenum, where there are two fittings without hoses :-}
Old Nov 27, 2008 | 02:15 PM
scope103's Avatar
Perhaps this will help:
Old Nov 27, 2008 | 04:18 PM
abecedarian's Avatar
one is connected to a port in front of the throttle body, the other goes to a fitting on the intake plenum. If you have air conditioning, or cruise control, there may be a "large" 'distribution' fitting (usually black in color) on the manifold which has 3 connections to it, of which one may be blocked (if you are lacking either of the aformentioned options).
but in essence, one sources air from in front of the throttle plate, and the other is exposed to full manifold vacuum, if that makes sense.
montanatruck
Feb 26, 2017 07:07 AM
keithporter83
Jul 24, 2015 07:37 AM
redghost.308
California SoCal
Jul 16, 2015 07:46 AM
voiddweller
Jul 15, 2015 03:56 PM
jon.r
Jul 11, 2015 03:34 PM
