bad vibes....
Old Aug 18, 2003 | 05:28 AM
data's Avatar
Senior Member
bad vibes....
Anyone know why I might be getting such bad vibrations when I push on the gas? It has just started happening. Any ideas? It seems to vibrate throughout the whole rig. I'm clueless on where to start looking. I check to see if the driveshaft was loose, but all looks well there.
Old Aug 18, 2003 | 06:50 AM
Tacoma Dude's Avatar
Does it happen when you're on neutral or park too?
Old Aug 18, 2003 | 09:40 AM
data's Avatar
Senior Member
I haven't tried it, but I'll give that a shot. Usually I've just noticed it while driving.
Old Aug 18, 2003 | 12:03 PM
Don't know much - only thing I can think of is unbalanced wheels? Maybe a weight fell off?
I'm only drawing from limited personal experience here - you've probably already determined this to not be the cause.
I only asked the question to clarify and get some of the "gurus" to reply
Hope you get it figured out soon!
Old Aug 18, 2003 | 08:19 PM
Skydigger's Avatar
Hit your driveshaft on any rocks lately?
Old Aug 18, 2003 | 11:18 PM
UKMyers's Avatar
U-Joint man! Not sure if the 3rd Gens have a carrier bearing but that may be it too. Crawl under your truck and wiggle the driveshaft by hand. It should be pretty apparent which one is bad.
Old Aug 19, 2003 | 07:28 PM
data's Avatar
Senior Member
I wiggled the driveshaft but it didn't feel loose.
Old Aug 20, 2003 | 12:45 PM
spoogy's Avatar
definitely ujoints - once they're burned they don't slop, they stick! that's what makes the rig vibrate so much
had all your same thoughts before my mechanic friend diagnosed the same symptoms - and he did it over the phone
Old Aug 20, 2003 | 07:48 PM
data's Avatar
Senior Member
Yup you guys were right once again. I pulled out the slip yoke tonight, but I couldn't get the ujoint out. I even tried a press, but still no luck. I guess I'll just take it to the dealership in the morning to see what they can do. I still get to drive my rig though. Luckily a buddy has a 96 Taco he's not driving tomorrow, so I kinda borrowed his yoke until tomorrow
Old Aug 21, 2003 | 12:25 AM
jx94148's Avatar
You can pull the whole shaft and use 4wd to get front wheel drive untill you get it sorted out. Good luck.
Old Aug 21, 2003 | 06:45 AM
data's Avatar
Senior Member
I took the yoke to the dealership this morning and they got the old ujoint out and replaced it with a new one that I had brought them. They didn't charge me a dime either! Another two thumbs up to the dealership
ghostmoney
Jan 28, 2018 11:42 AM
Blamalam
Aug 16, 2015 12:29 PM
corey519
Aug 12, 2015 11:12 AM
nonstop
7
Aug 11, 2015 09:26 AM
keithporter83
Jul 18, 2015 12:37 PM
