Help:Breaking the drive shaft nut loose
Old Nov 6, 2008 | 12:22 PM
PDX_1ton's Avatar
I'm about to pull my engine out and I'm wondering if it would be easier to break the drive shaft nut loose before pulling it out, or wait until I pull out the engine.
I thought about using the starter method.
thanks
Old Nov 6, 2008 | 12:28 PM
Alex 400's Avatar
thanks
you mean the crankshaft? If it is a manual trans, you could put in high gear with parking brake on to break it loose.
Old Nov 6, 2008 | 12:39 PM
abecedarian's Avatar
the starter trick works great while the engine's still in.
once the engine's out, an impact is the best way.
Old Nov 6, 2008 | 01:29 PM
PDX_1ton's Avatar
Thank you Alex, yes I mean the crank shaft.
I'll try to do it the manual while in gear method. I'm nervous at using the starter method now I have the throttle body off and fuel lines open.
Old Nov 8, 2008 | 09:40 PM
PDX_1ton's Avatar
FYI All,
I ended up using the starter trick. Had to unfuse the EFI (for the gas pump), remove all cables to from the distrbuter and hook up the battery again. One click of the key, a loud crack of the breaker bar hitting the cross member and I have a free nut.
Thank you all for the help.
Old Nov 8, 2008 | 09:49 PM
Old Nov 8, 2008 | 09:54 PM
Matt16's Avatar
FYI All,
A simple way would be just to pull the wire off the coil.
Whatever123
Sep 30, 2015 12:12 AM
redneck17
Jul 17, 2015 07:44 PM
Iceman4193
Jul 15, 2015 04:48 PM
HaydenConQueso
Jul 12, 2015 05:22 PM
Cdn-wilderness
Jul 10, 2015 07:43 PM
