warm starts, Oil light is on
Old Oct 22, 2008 | 06:58 PM
johnnyboy's Avatar
Arrow warm starts, Oil light is on
I,ve got a 22-re that apon warm start ups the oil light flikers and the engine makes horibal sluggish noise, I was woundering is this means that i'm getting low oil pressure or would it be a sensor fault?
Thanks yall for yer help!!
Old Oct 22, 2008 | 08:32 PM
abecedarian's Avatar
could be low oil pressure or a problem with the sender.
that didn't help at all, did it?
you'll need to put a pressure gauge on it and read the actual pressure. and if it's low, start fixing things.
Old Oct 30, 2008 | 10:30 AM
johnnyboy's Avatar
thanks ill give it a try!!!!!!!!!!!!!!!!!
Old Oct 30, 2008 | 02:06 PM
jasond's Avatar
If it is making noise when the oil light is on, and not when the oil light is off then its probably not a sensor.
Old Oct 30, 2008 | 09:31 PM
johnnyboy's Avatar
thats exactly what happens...when the oil light is on it makes a sluggish missing sound that slowly goes away untill the light is off and it only happens when the motor is warm...do you think it is a bad oil pump?
Old Oct 31, 2008 | 10:46 AM
Junkers88's Avatar
I'd say replace the oil pump.
Old Oct 31, 2008 | 11:44 AM
annoyingrob's Avatar
I would open the bottom end up, and determine if it's the pump or the bearings before I go changing pumps out.
If you have oil pressure issues, there's a good chance you've already done damage. Simply changing out the pump would be a band-aid at best.
Old Oct 31, 2008 | 04:22 PM
dbcx's Avatar
What weight oil are you using?
At only warm starts? It doesnt do it from speed to say stopping and idling at a red light?
What kind of mileage on the engine?
and X2 on a guage. maybe a permanent one
Old Nov 3, 2008 | 10:18 PM
johnnyboy's Avatar
Thanks ill try it but im thinkin about doing a new head gasket and also for the manifold and all that stuff, So do you have any usefull ideas about doing this process easer? Any useful info will be greatly appercieted!!!!!
Old Nov 4, 2008 | 08:42 AM
mnmontana's Avatar
Hate to ask..... but when was the last time you changed the oil? and what weight are you putting in?
Old Jan 13, 2009 | 09:58 PM
johnnyboy's Avatar
i use 10-30 oil,,,mabey the screens pluged with goooo.
Old Jan 14, 2009 | 06:52 AM
Marc's Avatar
Uh, maybe it's idling to low for a bit.
puddlepirate
Jun 30, 2015 05:08 PM
Alex Bessinger
Jun 28, 2015 10:05 AM
slider417
Jun 22, 2015 10:18 AM
jmc88runner
Jun 18, 2015 03:39 PM
Mutinebullfrog
Jun 18, 2015 01:36 PM
