My 22R-E burning oil..help!!!
Old Oct 22, 2008 | 08:04 AM
g_mau18's Avatar
Hey I just rebuilt the whole head on my engine, new valve cover gasket, head gasket, new valves, new camshaft, and It burns like a quart every 2 weeks, what the hell is going on?
Old Oct 22, 2008 | 08:19 AM
Toyotero's Avatar
Do you see blue-ish smoke in the exhaust?
If so, when? All the time when running or at start up after sitting overnight?
Have you done a compression test on it?
Old Oct 22, 2008 | 08:21 AM
g_mau18's Avatar
No, the smoke looks pretty white to me, and no I havent done a compression test, should I do one?
Old Oct 22, 2008 | 08:33 AM
874runnersr5's Avatar
if it is white, i would think it would be burning coolant?
Old Oct 22, 2008 | 08:48 AM
Cwaters1184's Avatar
sounds like the head gasket didnt seal properly. check your coolant level.
Old Oct 22, 2008 | 10:10 AM
abecedarian's Avatar
yes you should do a compression test.
also check that the pcv valve is operating properly.
Old Oct 22, 2008 | 02:59 PM
desert-rat660's Avatar
did u replace the valve seals? also now that the head is fresh it can cause more blomby past the rings now that the head should be sealing better
puddlepirate
Jul 30, 2016 06:29 PM
dzldust
7
Oct 6, 2015 05:39 AM
viesail
Sep 21, 2015 06:00 AM
sonorn67
Sep 19, 2015 05:39 PM
