Scary Sound. Almost like a tapping sound.
Okay, you know how when you are trying to drive your truck and you are going from neutral to first from a stop? Well this noise happens if you let the engine rpms drop too low and then add a lot of gas and release the clutch pedal accordingly. Doing this seems to cause a loud tapping or slapping sound.
On the one hand I avoid burning the clutch out his way, but on the other, maybe I am putting too much stress on the engine. Does anyone know what this sound means? And is it okay that it I've heard it a few times?
From a normal start in first gear (from a stop) there should be no pre-ignition.
If you lug the engine really bad under excessive load, you will get pinging/knock (pre-ignition).
I would try not to duplicate this sound if possible. There is no reason to lug it that bad out of first gear. You are not truly saving the clutch by doing that.
A properly driven 5 speed with the stock clutch will last 150K miles or more.
