Way confused about gearing
Old Oct 18, 2008 | 02:05 PM
Duartizzle's Avatar
I just bought a 94 runner 4x4 auto. the owner before me installed the toyota e-locker and has been running with 4.88 gears with 31" tires. I am looking into getting some mud terrains, but aren't the 4.88 gears supposed to be paired with a bigger tire? should i look into getting a bigger tire? or change the gearing to 4.56?
Old Oct 18, 2008 | 02:14 PM
Squeebs's Avatar
with the auto, you want 4.88 with 31's, otherwise its a complete dog.
Old Oct 18, 2008 | 03:25 PM
jason191918's Avatar
X2...
4.88 and 33's for a manual
Old Oct 18, 2008 | 03:26 PM
dropzone's Avatar
Fossilized
It would not be worth the money for such a small change from 4.88 to 4.56 gears. As Squeebs said, with the auto you want the 4.88's. You could probably go up to a 32x11.50 but I would recommend staying with a 31. E-locker is a great addition.
Old Oct 18, 2008 | 05:34 PM
Matt16's Avatar
Going from 4.10 to 4.56 was definitely worth it.
Old Oct 18, 2008 | 05:40 PM
abecedarian's Avatar
if you install a smaller tire than what's on there now, you'll probably notice the engine at slightly higher rpm's for any given speed, a little extra 'pep' in the 'runner's attitude and maybe a small decrease in mileage... and I really mean 'maybe'- mileage could actually go up if the engine's not having to work so hard to turn the tires.
Old Oct 18, 2008 | 06:16 PM
Junkers88's Avatar
Indeed! Although we have standards. The auto is a different beast all together.
Old Oct 18, 2008 | 06:20 PM
Matt16's Avatar
My point was simply not to underestimate changing the gear ratio by one step (ie: 4.10 to 4.56, 4.88 to 5.29)
Old Oct 18, 2008 | 06:22 PM
Matt16's Avatar
With regards to the OP, you've got a great setup as is, but if you want to change to 4.56s and you're in the Pacific NW, give me a shout, I'll swap with you.
Old Oct 18, 2008 | 06:26 PM
And I'm your midwest connection.
Old Oct 18, 2008 | 07:53 PM
RatLabGuy's Avatar
FWIW, I have an auto tranny, and now running 5.29s with only 32" ATs... AND I LOVE IT.
That auto really makes it a dog; having the RPMs up as high as possible so it's in the functionally usable range really makes a big difference.
Old Oct 18, 2008 | 08:04 PM
Byota's Avatar
are 5.29's ok for 38 krawlers with a manual and 3.0l
Old Oct 18, 2008 | 08:08 PM
Junkers88's Avatar
Does keeping it up in the powerband make it better on economy? Just wondering.
Old Oct 18, 2008 | 08:10 PM
Junkers88's Avatar
Although I don't know much about the 3.0 I have read that 5.29's are good for up to 35's depending on how much you value mpg's, if it's also a daily driver. Most folks that run tires in the 36+ range run 5.71's from what I've read.
Old Oct 18, 2008 | 09:08 PM
X2...
Old Oct 18, 2008 | 11:44 PM
Matt16's Avatar
Probably won't be terrible.
Old Oct 18, 2008 | 11:48 PM
Duartizzle's Avatar
Thanks guys, I will stick with the 31's then. Going to get some mud tires. Yeah, I really scored on this new rig, the previous owner did so much to it. elocker, aisin manual hubs, dual power seats from 04 honda accord, marlin rear bumper, rock sliders. its amazing
Old Oct 19, 2008 | 07:16 AM
Junkers88's Avatar
Might I recommend treadwright.com?
mskalmus
May 28, 2017 07:51 AM
jetpilot
Aug 15, 2015 06:48 AM
wolfpackfan33
Aug 2, 2015 03:36 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
