96 4runner 3rz O2 sensor Resistance?!?!
I just threw a p0420 (Catalytic converter efficiency Bank 1) and i wanted to test my O2 sensors. Does anyone have the resistances that Sensor 1 and Sensor 2 should be??
1996 4Runner 4x4 4cylinder (3RZ)
Thanks in advance for the Help!
INSPECTION
1. INSPECT HEATER RESISTANCE OF HEATED OXYGEN
SENSOR
(a) Disconnect the sensor connector.
(b) Using an ohmmeter, measure the resistance between terminals
+B and HT.
Resistance:
at 20°C (68°F) 11 – 16 ohms
at 800°C (1,472°F) 23 – 32 ohms
If the resistance is not as specified, replace the sensor.
Torque: 20 N·m (200 kgf·cm, 14 ft·lbf)
(c) Reconnect the oxygen sensor connector.
SENSOR
+B and HT.
Resistance:
Same Resistance Sensor 1 and 2??
So what i assume from the replies are the resistances should be the same for both Sensor 1 and Sensor 2, even though they are different part numbers??
Thanks for the references too!!
if it is a different part number, then the front one is likely an air fuel sensor
not an o2 sensor,
and resistance test is not gonna fully diagnose jack.
however, code 0420 -is- the rear sensor, or bad cats, so the
rear in fact is an O2 sensor and the resistance test applies
not an o2 sensor,
RyanJ989
11
Apr 7, 2021 09:41 AM
Longbed 90
Mar 11, 2019 12:38 PM
zz_denis
Sep 6, 2015 03:43 PM
LJR
Sep 5, 2015 06:02 AM
