need help with clunk!
Old Sep 6, 2008 | 02:20 PM
93toyrunner's Avatar
I have a 93 toyota 4runner, when ever I am turning and I hit ab ump does not matter if it is small or big, I here a lond clunk on the drivers side, somtimes it fells like it is close to my feet, I was thinking it is either BJ's or bad shocks, possibly some kind of steering link in front, because it only happens when i am turning, it does not matter the speed either, but it is a little more noticable a slower speeds like when pulling out of parking lot, Any ideas would help thank you.
Old Sep 6, 2008 | 02:55 PM
abecedarian's Avatar
sway bar or control arm bushings, possibly a shock bushing
could be tie-rod end or ball joint
remote case it could be a brake caliper is loose.
Old Sep 7, 2008 | 06:34 AM
leebee's Avatar
get the front end up in the air safely and start checking things out. turn the wheel and look for things moving that shouldnt. abe gave you a pretty good starting point, have at it!
let us know what you discover.
lee
Old Sep 7, 2008 | 06:41 AM
Team420's Avatar
Bet u are hitting the bump stops.... my rigs do that same thing when I turn the wheel all the way, and give a little gas....otherwise....yeah...what abe said.
Old Sep 7, 2008 | 07:58 AM
clunk
thanks guys for all the help, I never thought of the bump stops evrn though they are to close to hitting all the time, If I keep hitting the bump stops does this mean my shocks are bad or maybe my TB need to be turned a little.
Old Sep 7, 2008 | 08:26 AM
Team420's Avatar
I have just dealt with it....u could just throw some grease in there...might help.
Old Sep 7, 2008 | 10:32 AM
affmondo22's Avatar
It could also be the inner joint of your cv shaft. They clunk instead of clicking like the outer joint of the shaft
Old Sep 7, 2008 | 01:05 PM
I am almost positive it is not the cv shaft because I have manual hubs and the cv shaft never spins
Old Sep 7, 2008 | 01:47 PM
JCM4x89pu's Avatar
common problem... it's the joint on the idler arm.
Old Sep 7, 2008 | 07:16 PM
is the idler arm on the drivers side cause that is where the clunk is, and can I fix this with the bushing kit or is it all junk.
runnygirl19
Nov 19, 2015 11:39 PM
Naween Zohab
Nov 10, 2015 03:56 PM
BK2TFUTURE
Oct 11, 2015 08:42 PM
Odin
Sep 26, 2015 06:56 PM
altydog
Sep 20, 2015 07:37 PM
