What's the largest wheel size you'd run if going off-road?
So I wouldn't say that I go offroading like many of you all do here on Yotatech....the only play I get is some harsh backroads up here in the NC mountains for the most part.
I'm getting ready to get some new wheels so I can do the Tundra Upgrade on my brakes and am curious if I should go with 16 inch wheels or something larger?? By no means do I want 22s or anything like that to PIMP out my ride!!
I know that the larger my wheels are the less rubber I'll have on the tire for airing down though.
So what's the ideal wheel size for a 3rd gen that is a daily driver with some pretty good backroad (and these roads have not been maintained in years) travel about once a week?
265/75 as I'm not going to put a lift on. I think it's the biggest I can go without rubbing.
I'm gettin ready to hit a local salvage yard that says they have some 16 inch Tacoma wheels there. I think they are off a Tundra though.
Is there a difference?
Also, if I have 15x7 wheels now do I need to get 16x7 Toyota wheels or 16x8??
I just want to know what I'm looking at when I get there.
Thanks!!
Thanks!!
Well....I got some 231mm Tundra calipers for 70 bucks but the rotors they had were rusted to death so I'll just buy some new ones.
The wheels....well, they had a brand new 4 runner with 17 inch alloys but wanted 500 bucks for those wheels. They also had some 16 inchers but wanted 250 for those wheels. Too rich for my blood especially when I can get some new procomps for around 400.
As much as I like my 16" Procomp wheels, If you care about the looks factor, I would go at least 17s, maybe even 18". Yes, the price of the tire goes way up (that's why I didn't do it). But if I had the extra $$$ laying around, I would have gotten a larger wheel.
As for just off road factor, I would stick with 16's.
Are there any differences between your factory wheel width and the procomps you have? Also...what offset and backspacing did you get on your wheels?
Thanks Psraff!
How are they with the outside of your vehicle? Are they flush or do your tires come out past your fender flares?? I don't want mine coming out past my flares. With 16x8 I'm worried about that.
Thanks Psraff!
Thanks Psraff!
As you can see they come past just a hair (they are 265/75-16, compaired to 265/70-16 stock) They were a little wider compaired to my 265/70s. Don't know if that has to do with the wheel or the make\model difference of the two tires. Also, I just have that little trim piece. I don't have the limited or bushwacker flares (yet). When I ordered my tire\wheel package, I gave them my my make and model and year and told them it was stock suspension. So they matched the width\offset to the stock wheel. I just dug out the invoice for them..
They have:
Wheel Size: 16x8
Bolt Pattern: 6x5.5
Lug Size: 12x1.50
Backspace: Left Blank....
Hope this helps some....
[/IMG]
[/IMG]
