Jeep AW4 TCU to control a340h in 1UZ swap(x-jeepters chime in!)
I have been doing a lot of searching on this and was wondering if you old xj jeepsters could help me out
This is what i know (or think i know)
The Jeep AW4 is made by Asian Warner and is remarkably similar to the A340F
internals and solenoids similar a340H (tcases aside)
The Jeep AW4 uses a transmission control Unit (TCU) to regulate all solenoids.
The solenoids are very similar (possibly interchangeable with a340x's)
here is the question...
I am about 2 weeks away from putting a 1UZ in my 1994 4runner, can I wire an AW4 TCU to control my transmission (a340h) instead of having the 1UZ ecu try and interpret/send the incompatible signals? This is a wiring diagram for an AW4 with Economy/Power switch similar to our transmissions.
http://www.greatlakesxj.com/tech/TCU4.jpg
AW4 TCU inputs:
TPS
Brake switch
economy/power switch
12 v (switched)
speed sensor
I’ve seen Lextreame.com uzswap.com but never heard anyone speak of this option. Am I just thinking about this wrong? Thanks!
AW4 TCU inputs:
TPS
Brake switch
12 v (switched)
speed sensor
Ecu
Well if I'm not mistaken you have left out the fact the the ECT is connected to the ECU. The info I found is that ECT takes signals from the ECU to tell when to shift the transmission. There are only a few wires that actually are connected to it, basically two speed sensors, a pressure sensor, gear lever position and solenoids? Iwould also like to know if the signal are different, seems unlikely but who know.
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
Sep 9, 2015 06:24 AM
kirkrunner
Jul 27, 2015 07:59 PM
MTLroadierunner
Jul 20, 2015 03:07 PM
asian, aw4, crankshaft, guzzi, jeep, manual, modifications, moto, pressure, sensor, shift, solenoid, swap, transmission, wiring
