Does/did Suzuki use the same aisin locking hubs
From: Grew up in S.C.V, So Cal.....now in Hampstead, NC
on thier samurai's, that are on our Toyotas? Or are the intrnals different? The face dial's look the same
Here's a quote from http://www.off-road.com/offroad/arti....jsp?id=399668 :
The Suzuki and 30-spline Toyota hubs are virtually identical except for the inner hub. The grips on the dial of the 30-spline Toyota hub stick out slightly beyond the cap, where on the others, it is flush. Functionally, the dials are interchangeable between the Suzuki and 26- and 30-spline Toyota hubs. The 26-spline (IFS) Toyota hub has a deeper backspacing between the mounting flange and the inner hub than the other hubs, in order to clear the spindle nuts. Because of this, the Suzuki or 30-spline Toyota hub body will not fit on an IFS toyota wheel hub, but the reverse should work; i.e. a 26-spline Toyota hub body should be usable on a Suzuki or 30-spline Toyota hub.
Good luck, just did mine yesterday.
Scott
Scott
Ok, so the 26 spline zuk won't work on my 91 add for conversion. Wasn't sure, guess that's why they're on ebay for less than $20, and the Toy's are over $70 on bid...thanks
FS[FourCorners]: First Gen Tacoma/4Runner Manual Hub Spindles
G-off
Dec 29, 2015 12:44 PM
zz_denis
Sep 6, 2015 03:43 PM
FS[PacNorWest]: 1993 4 Runner, V6, 4wd, Auto,
AkitaDog
Sep 3, 2015 09:01 PM
