solid front brake lines; is there a better way?
94 4x4 22RE 194k
I just changed my pass side brake rotor and need to do the driver's side. The crappy brake line design requires me to break the line open to remove the caliper from the knuckle.
Two questions:
Is there a recommended upgrade to bring a flex line to the caliper from the frame?
Is there a good way to temporarily plug the brake line to minimize fluid loss during the brake job?
Two questions:
94 4x4 22RE 194k
Two questions:
Two questions:
On my solid front axle brakes, I just notched out the bracket where the hard line attaches. That way, you can pull the little clip that holds it in place and the n slide it out of the notch to pull the caliper away.
I use a vacuum cap to slip over the threaded end of the brake line to keep fluid loss to a minimum. I picked up a kit like below and the red caps are a perfect fit for the brake lines:
Jun 1, 2021 01:51 PM
Sep 4, 2015 09:27 AM
TokyoD23
Jul 12, 2015 06:01 AM
