need a coulpe plugs from 22re harness
i need 2 injector plugs and the plug for the sensor on the thermostat. not sure if that last one is a coolant temp sensor just cuz i have another thermostat housing that dosent have a port there so... anyways all the yards by my house have no toyota trucks and yards that do only sell complete harnesses. so if you can go snip them for a yard near you let me know and ill make it worth your while just make sure to leave as much wire intact as possible. its for an 86 4runner 22re pm me if you can help thanks!
Do you need the connector itself or the connector with some length of wire? I have a 3.0V6 and when I pulled the engine out the injector connectors were brittle and broke.
I bought 6 from from Lexus (I work there) for $4.00 a peice. I can post the part number if you need it.
