Bad clutch cause Head gasket to fail??
Old Jul 8, 2008 | 09:14 PM
path's Avatar
Mechanic says my clutch was slipping causing computer to lean out injectors and burned up between two cylinders. this possible?
o ya and supposedly two injectors were junk so they were all reworked.
Could the o2 sensor be to blame or something else? I want to make sure this doesn't happen again.
Now I am putting in a new MC clutch, shifter bushings, and master and slave cylinder. What kind of fluid should I use for the clutch cylinder??
Old Jul 8, 2008 | 09:28 PM
ozziesironmanoffroad's Avatar
ok... dude... put down the crackpipe... lmao! i had never heard that one before... thats a good one to use to mess with someone... ok heres the breakdown. the computer has no idea about the clutch, its concerned with the engine. my clutch is covered in oil, yet throws no codes. the clutch slipping does NOT cause the computer to lean out the injectors. use DOT-3 or 4 fluid in it. synthetic if possible. and do a compression check in all cylinders, supposed to be around the 160-170ish range. oh, one more thing: get a new mechanic, this dilweed obviously was trying to get more money out of you.
hows does the truck run? does it misfire, idle really weird, no power, etc?
Old Jul 8, 2008 | 09:54 PM
path's Avatar
first i had a bad spark plug that melted due to a bad helicoil, so i burned an exhuast valve cyl #3. had all the head work redone. one month later my head gasket between #1 and 2 burns through to each other on my way up to the mountains. in the middle of the nite with no cell service so i kept going, sounded like a rod knock. found later to be the HG, now mech says the something that the slippin clutch is makin the engine work more or something and causing it to overheat or something and letting the computer lean it out. i dont know, it sounds strange and i don't want my truck to have any more issues, so what else should i check. cuz i dont want to spend anymore money fixing it.
seems to run ok now but waiting to get a clutch before i drive it.
Old Jul 8, 2008 | 10:03 PM
path's Avatar
what else could have cause the HG to burn up between the two cylinders?
Old Jul 8, 2008 | 11:42 PM
Jay351's Avatar
Well, like Ozzy said, the computer has no idea the clutch is there.
Our trucks are not capable of leaning out the engine from sensing a clutch slipping.
As for your HG, shotty hg, overheating (make sure your cooling system is in tip top shape), possible past bad workmanship.
What else has this mechanic done on your ride?
Old Jul 9, 2008 | 01:13 AM
Matt16's Avatar
I had a V6 4runner for ONE day. The clutch started slipping and then the rad sprung a leak when it overheated. Neither had ever happened before according the AA.
Old Jul 9, 2008 | 10:27 AM
Jay351's Avatar
It was a sign You truley wanted a 22re
Old Jul 9, 2008 | 10:38 AM
Matt16's Avatar
Probably.
Old Jul 9, 2008 | 02:24 PM
abecedarian's Avatar
after loling a bit...
you had a headgasket blow and then they found two bad injectors... my guess is the two bad injectors leaned the mixture out which caused the hg to blow.
the only thing I see the clutch being able to contribute to is the excessive slippage causing higher rpms
Old Jul 9, 2008 | 08:54 PM
path's Avatar
if it overheated wouldnt the temp gauge have moved, or is that just a dummy gauge?
ok so now that everything is done. what should i do to my cooling system?? obviously a flush. what else?
Old Jul 9, 2008 | 10:48 PM
CyMoN's Avatar
did he install a new head gasket when they worked on the head?
Old Jul 9, 2008 | 10:50 PM
DeathCougar's Avatar
I think its time to find a new mechanic
Old Jul 9, 2008 | 11:00 PM
a4runnerfreak's Avatar
From: Grew up in S.C.V, So Cal.....now in Hampstead, NC
new mechanic....x2!
Old Jul 9, 2008 | 11:04 PM
Jay351's Avatar
Well I have heard that once the temp guage gets to its normal position, it won't move any hotter till it gets 30 degrees hotter.
But that might be false, but they are known not to be the most accurate..
Colington
Mar 8, 2020 09:51 AM
Sep 4, 2015 09:27 AM
smiley52
Jul 11, 2015 05:16 AM
Coreyr384
Jul 10, 2015 11:13 AM
87blyota
Jul 10, 2015 04:31 AM
