Is it possible to use a class 4 hitch?
Depends what you mean. Its possible, sure. You could also put a class 4 hitch on a geo metro. You could also put one on a moped.
Is it realistic is hard to say. Number one Class 4 is 4,000 pounds, so if you are hauling that much, thats pushing not only the engine, but the suspension and brakes of the yota. Anything heavier than 3,000 I like to have a 3/4 ton.
However, it can be done. If the trailer is equipped with trailer brakes, and you are very careful, I would tow 3-4k on flat ground for short distances. However, hilly ground, or long distances, or any distance/grade without trailer brakes, would be a no-no.
Basically I wouldn't do it.
Well i am not getting it solely for towing. I am simply using a dirt bike carrier to carry to bikes on my runner. the class 3 hitch only allows 500 pounds at the tongue. I need atleast 650 at the tongue, so I am thinking that a class 4 would allow more than 500 at the tongue
so you want to hang that much weight off the back of a vehicle that already has a reputation for saggy rear springs?
Class 4 hitches are usually limited to 600 lbs of tongue weight. Save the money and just buy yourself a small trailer from someplace and haul your bikes with. IMO in the long run it would be the better move.
mirabile4runner
Sep 3, 2015 07:15 AM
shadowbirdie
Jul 21, 2015 10:38 PM
