Wheel question
Old Jun 18, 2008 | 06:32 PM
20twinz's Avatar
Question Wheel question
I have a set of steel wheels on one truck and aluminum on the other.
(not the aluminum wheels in the avatar, they are gone. They look like off the Dukes General Lee.)
What is better to run?
It will be a daily driver and hard core mud runner.
If the chance for rock crawling comes up I will accept but thats a shot in the dark here in Iowa.
I'll have 33"+ size tires on it if that makes a differance.
Old Jun 18, 2008 | 06:41 PM
shaw_j's Avatar
Aluminum's are lighter, which is good for the DD purposes
Old Jun 18, 2008 | 07:04 PM
20twinz's Avatar
Same thought but then I think of muddin' and catchen a rock, stump, log, anything that might be under it that shouldnt be, and if the aluminum wheel will hold up or not?
Old Jun 18, 2008 | 07:14 PM
shaw_j's Avatar
Well wheeling with fancy and shiny rims is just going to make you sad.
The second you put that first scratch in them....... you'll know what I'm saying
Old Jun 18, 2008 | 07:39 PM
20twinz's Avatar
Oh totally! I dont plan on any bling for an off road vehicle. I got a 2wd on 22" wheels for that. I have the General Lee aluminums (just old looking wheels on the one yota) or stock steel wheels off an 89 yota that I would paint black.
Old Jun 18, 2008 | 08:05 PM
CC_yota's Avatar
If you bend a steel when it can be fixed, if you bend an aluminum wheel it has to be replaced.
Old Jun 23, 2008 | 10:25 AM
blueyoda's Avatar
northern taco just punched a hole in his stock aluminum rim doing some MILD WHEELIN, I never trust AL rims, they leak, they corrode, and bi metalic weld on the front hubs can be a wh*#&. I went with steel stock and I am happy.
Old Jun 24, 2008 | 03:59 PM
20twinz's Avatar
Question
Okay, when I do get the truck road worthy I will run the steel wheels with some decent tires to get buy on. (stock size wheels and a little larger tire)
I want to run a 33x12.5 tire or larger. It will have a 2" body lift.
Now the Questions:
1: Is it correct that I DO need a 10" wide wheel to fit 12.5" tires?
2: If so, what would the back spacing be for my 85 4WD? (I dont want spacers)
3: Any suggestions for a site that offers cheap wheels like a 15x10" with the proper back spacing?
Thanks all!
Old Jun 25, 2008 | 03:46 PM
20twinz's Avatar
Okay, eBay is the way to go for wheels. Found a set of Pro Comps for like $300 shipped. 15x10's
However, thinking of going with 10.5's now for tire width instead of the 12.5's so if I dont want to buy a 10 wide wheel I can run my stock steel wheels.
Still wondering-> what backspacing is needed for 10 wide wheels and 12.5 wide tires? (for later references)
Old Jun 26, 2008 | 04:52 AM
blueyoda's Avatar
Good choice on 10.5, I am a firm believer in PIZZA CUTTERS, I love the 10.5 (really 9) tsl's, easier for the motor to keep rpms up.
Old Jun 26, 2008 | 05:17 AM
20twinz's Avatar
That and, living in Iowa and dealing with the snow, a slimmer tire will work much better.
Old Jun 26, 2008 | 06:23 PM
20twinz's Avatar
So I did some messuring today on the wheels I have and this is what I came up with.
The steel wheels I would be getting off an 89 yota have a 4.5" back spacing which is WAY to much. It rubs on the sway bar very bad. These wont work for me now. I dont want to use spacers.
The aluminum wheels that are on my white parts truck have a 4" back spacing messurment and already had a 1/4" spacer behind them. They clear with it but rub with out it.
With this I have come to the conclussion that I will have to temp. use the aluminum wheels with the spacers and the used 33's to get me by for now untill I can get some $$$ for nice wheels and tires.
Old Jul 2, 2008 | 07:44 PM
20twinz's Avatar
New Project Thread Started
I have a new thread started with more info and the build of my rigs. We can all let this thread make its way to the bottem now.
Check it out!
https://www.yotatech.com/forums/f115.../#post50865142
glowz825
Jan 25, 2022 09:28 AM
coffey50
Jul 28, 2015 10:55 AM
rushw
Jul 18, 2015 01:46 PM
87turboPA
Jul 12, 2015 07:49 AM
87turboPA
Jul 9, 2015 05:58 AM
