any good offroad valve stems out there?
Old Jun 17, 2008 | 08:56 PM
mr x's Avatar
I just cut a valve stem on the rocks the other day, is there a company that makes a hardcore stronger, shorter more flex able valve stem?
ozziesironmanoffroad's Avatar
sure, get a metal one.
Old Jun 17, 2008 | 09:04 PM
Kaleb's Avatar
I remember seeing a recessed stem that a guy was running in the sand. Don't know who makes them, but he was telling me that they worked pretty nice, and were safe from objects on the trail. Only thing was he needed an adapter to fill up the tire.
Old Jun 17, 2008 | 09:32 PM
Alex 400's Avatar
yeah seriously, it's the cheapest and easiest way. My dad has them on his f-250. they have a 3/8 nut that screws the stem to the wheel. those are also on steel wheels just fyi
Old Jun 17, 2008 | 09:38 PM
CJM's Avatar
CJM
Get small valve stems like the 1" ones, they dont stick out at all really or metal ones.
Old Jun 17, 2008 | 10:18 PM
id say metal ones, they dont rot like rubber ones do, and theyre much stronger
Old Jun 18, 2008 | 08:44 AM
kd's Avatar
kd
dont metal ones snap out of the hole instead of bend? i was toldnot to use them for that reason.
Old Jun 18, 2008 | 08:55 AM
mt_goat's Avatar
I didn't like the metal ones because they leak after a year or two. There was a nut on the inside of the tire on mine that you had to take the tire off to tighten up. Too much maintenance for me.
Old Jun 18, 2008 | 09:46 AM
AusTex's Avatar
Here is a link to what you need to get.
http://stores.channeladvisor.com/tir.../Items/504_set
They will give you more rockcrawling power. 8P
Old Jun 18, 2008 | 10:33 AM
runner00's Avatar
Here is a good write up on pirate 4x4
/www.pirate4x4.com/tech/billavista/valve_stems/valve_stem_protection.htm
Old Jun 18, 2008 | 12:01 PM
markcuz's Avatar
Mr. Gasket makes them. I ran them on my Celica for a while. A real pain to fill the tire with air when using this type. Part # 5102
Old Jun 18, 2008 | 12:12 PM
norcalsvx's Avatar
Originally Posted by runner00
yea any tire shop should have the longer brass ones
Old Jun 18, 2008 | 02:35 PM
Crawdad's Avatar
Alternately, you could relocate the valve stems either further in, or on the back side of the wheel. Not hard to do, just requires that you take the tires off, and you have to plug the other hole (obviously).
May not be the best option, just throwing an alternative out there.
Old Jun 18, 2008 | 02:42 PM
abecedarian's Avatar
and carry a tube or two just in case.
Jun 1, 2021 01:51 PM
Sep 4, 2015 09:27 AM
razorman8669
Jul 12, 2015 12:13 PM
Yotoder865
Jul 9, 2015 07:51 PM
Gamble_STi
Jul 7, 2015 07:54 PM
