WTF Clutch dont fit--lil help guys
Old Jun 15, 2008 | 04:21 PM
dcuzz23's Avatar
well i was under the impression that either flywheel will work 3.0 of 3.4, and that you need the 3.4 clutch,p-plate,and pilot bearing with 3.0 release bearing.sooooooooooooooooooooo the 2000 3.4 pressure plate doesnt fit my 94 flywheel. im kinda not surprised but i expected it to fit since people said either flywheel could be used. what do i do-get a 3.4 flywheel? is the early t100 use a diferent setup? any info greatly-appreciated
Old Jun 15, 2008 | 04:31 PM
dcuzz23's Avatar
im just cofused how some say it will work and others say use the 3.4 flywheel. was it bad info i read or am i justa flippin idiot? just curious
Old Jun 15, 2008 | 04:52 PM
DeathCougar's Avatar
http://offroadsolutions.com/technica...#transmissions
Methinks you should use the 3.4 flywheel
Old Jun 15, 2008 | 05:03 PM
thefatkid's Avatar
You can't mix and match pieces like that.
A. use stock 3.0 flywheel ,clutch, pressure plate combo. (smaller friction surface though)
B. use 3.4l flywheel ,clutch, pressure plate combo.
If using a 3.0 tranny, use the 3.0l throwout bearing. If a 3.4 tranny is used, use the 3.4l throwout bearing.
Pilot bearing doesn't matter.
Old Jun 15, 2008 | 06:58 PM
Elvota's Avatar
Parts required:
3.4 pressure plate
3.4 clutch
3.4 Pilot bearing
3.0 Throwout bearing
More info:
https://www.yotatech.com/forums/f160...4-swap-128285/
Old Jul 3, 2008 | 04:58 PM
dcuzz23's Avatar
yeh guys bought the 3.4 flywheel---thanx
jasonty
41
Dec 23, 2018 01:00 PM
adammtb
Jul 27, 2015 11:57 AM
1996Taco
Jul 20, 2015 12:02 AM
Kalihi,HI
Jul 9, 2015 04:29 PM
timmJ
Jul 7, 2015 02:01 PM
