WTF Clutch dont fit--lil help guys
well i was under the impression that either flywheel will work 3.0 of 3.4, and that you need the 3.4 clutch,p-plate,and pilot bearing with 3.0 release bearing.sooooooooooooooooooooo the 2000 3.4 pressure plate doesnt fit my 94 flywheel. im kinda not surprised but i expected it to fit since people said either flywheel could be used. what do i do-get a 3.4 flywheel? is the early t100 use a diferent setup? any info greatly-appreciated
You can't mix and match pieces like that.
A. use stock 3.0 flywheel ,clutch, pressure plate combo. (smaller friction surface though)
B. use 3.4l flywheel ,clutch, pressure plate combo.
If using a 3.0 tranny, use the 3.0l throwout bearing. If a 3.4 tranny is used, use the 3.4l throwout bearing.
Pilot bearing doesn't matter.
Parts required:
3.4 pressure plate
3.4 clutch
3.4 Pilot bearing
3.0 Throwout bearing
More info:
https://www.yotatech.com/forums/f160...4-swap-128285/
3.4 pressure plate
3.4 clutch
3.4 Pilot bearing
More info:
jasonty
41
Dec 23, 2018 01:00 PM
