? about ext. length shocks
Old Jun 9, 2008 | 12:29 PM
lexustech's Avatar
just got my pp spings on, i need to get some extended travel or length front shocks, how /where can i find these i guess the shock will be the same length just the shaft ticks out farther,thanks in advance
Old Jun 10, 2008 | 08:14 PM
lexustech's Avatar
ok i just got a email back from toytec they said the longest front shocks they have are OME but they are only a half inch longer, is there any others out there? where can i order them? does anyone know if tokico makes ext. travel shocks? what are you guys running
Old Jun 10, 2008 | 08:20 PM
crolison's Avatar
I dont think it should be much of a problem if those are the 1" pp springs. I was running stock length shocks and 3.5" of lift and it wasnt horrible, my flex was limited though.
Old Jun 16, 2008 | 09:55 PM
MauiJim's Avatar
In my research on PP springs, it seems that many are running them with Tokico Trekmasters with good results (ride quality, and length). I just ordered a set of Tokicos off eBay, and should have the PP springs on this weekend, if you'd like some firsthand experiences.
Old Jun 17, 2008 | 08:33 AM
lexustech's Avatar
thanks,definately keep me posted i beleive those are what im gonna get
Old Jun 18, 2008 | 11:03 AM
cox380's Avatar
you dont need longer struts up front. The down travel of the front suspension is limited by it's geometry so even with longer struts you won't get more travel.
Old Jun 19, 2008 | 05:06 AM
BajaRunner's Avatar
Its been researched quite a bit, but the longest recommended shock you should use is an OME shock. Your flex won't be limited by the shock, yet by the makeup of the IFS, which is not designed to have very much travel.
The CV's and tie rods are the first that would break if you did end up trying to put a longer shock up in the front.
Also, remember that the shocks are inboard from the tires, so 1" of travel at the shock will equate to more than 1" travel at the wheel due to the longer radius, and sweep a longer arc..
ladybugRC
458
Aug 21, 2020 10:41 AM
ZGjethro
Jun 7, 2017 11:04 PM
dirk89
Oct 1, 2015 05:15 PM
ktm192k
Oct 1, 2015 08:47 AM
hiluxinargentina
Sep 30, 2015 05:51 PM
