What's the name fo this hose?????
Old Jun 5, 2008 | 04:38 PM
Hyperwrx's Avatar
Exclamation What's the name fo this hose?????
Sprung a pin-hole sized leak and the local auto parts place can't find it in their books. It's leaking anti-freeze/water. The hose appears to be wire reinforced and has an outlet that goes to a heater hose.
Any help on IDing this hose would be appreciated.
Picture for reference.
Old Jun 5, 2008 | 04:53 PM
just a 22re's Avatar
lower rat hose from engine to the elbow hope it helps
Old Jun 5, 2008 | 05:06 PM
Hyperwrx's Avatar
That's not the lower radiator hose.
The lower radiator hose is the hose in the lower left hand corner of the picture.
Old Jun 5, 2008 | 05:21 PM
abecedarian's Avatar
take the hose off and take it to the parts place.
Old Jun 5, 2008 | 05:26 PM
DaveInDenver's Avatar
That's the hose that connects the water pump to the metal elbow. I'd probably call that the water pump outlet hose to the NAPA guy. But like abecedarian says, take the hose to the parts counter and match it. Doesn't matter what you call it as long as it matches the new one.
Old Jun 5, 2008 | 05:48 PM
Hyperwrx's Avatar
Thanks guys. I'll do that
Old Jun 5, 2008 | 05:51 PM
Kiwipushrod's Avatar
Hey Hypewx, (see it does'nt work, does it)
I could possibly Help You, with Your problem......
If You Could simply add an "r" to Your thread title, right next to "fo",...I would then, be more inclined, to do so.
If You need to Borrow an "r", I can also help You with that, just PM Me, and I will send it, in short order.
Thanks, Kiwi
Old Jun 5, 2008 | 06:02 PM
Thanks, Kiwi
I've deposited an excess of "r" to the Interwebs.
Kiwi- feel free to draw from them.
Old Jun 5, 2008 | 06:03 PM
See... I've got "r" to spare.
Old Jun 5, 2008 | 06:06 PM
leebee's Avatar
maybe reverse the letters, of?!
lee
Old Jun 5, 2008 | 06:14 PM
ok so i was off by a lil bit but thats what i called it when i got mine new i said lower rad hose and they said what one the 1st or the 2nd i said the short bended one and they looked at the pic and thats what it was it goes from the pump to the elbow and then the elbow goes to the lower rad so its the 2nd lower rad hose but thats just what the store calls it so i dont know
Old Jun 5, 2008 | 06:16 PM
iamsuperbleeder's Avatar
When I replaced mine with my water pump, they just listed 2 lower hoses; pump to pipe, and pipe to rad... that would the the pump to pipe one... but yeah, just bring it with you up to the parts store.
Old Jun 5, 2008 | 07:13 PM
Hyperwrx's Avatar
Sorry for the unintentional gang-related dialog in the title. It was an error in my typing rest assured.
I took the hose off and took it in to find out they don't have anything resemling it. I guess I'm off to the service counter at the local Toyota dealer.
Thanks again gentlemen.
Old Jun 5, 2008 | 07:17 PM
autozone dont have it??? ha ha!!!
http://www.autozone.com/N,16300787//...eResultSet.htm
Old Jun 5, 2008 | 11:40 PM
you must be getting the newbies at the parts store...
The guy I talked when I got mine knew exactly what I was talking about... but he's also an old school parts house guy that's ASE certified... it's why I go back to him every time. Try out an Advance Auto Parts first before the stealership; that's were I got mine from.
I have 3 of their part numbers for hoses (stuck in my repair manual in the little notes section) that I got when I did my H2O pump...
B70815
B71383
C71262
Tell the guy (or gal) at the counter that you want to see those three hoses; I'm not sure which one is which; they don't have descriptions on the stickers that I kept, and it's been so long since I messed with them; but tell them a former employee told you one of those are the ones you need. I worked there for 2 and a half years; I KNOW they have them...
Old Jun 6, 2008 | 05:05 AM
Workhorse's Avatar
Just for additional info if anybody else runs into this problem as well.
Napa Part #: NBH 7564
In their system it is named:
Hose - Radiator Lower: Comment: Engine to Pipe @Cut to Length@
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
wberry85
May 17, 2016 05:45 PM
kcaudill
Oct 10, 2015 02:39 PM
taraf
Sep 25, 2015 02:57 PM
