1988 SAS truck, $3200, Delaware
1988 SAS truck, $2800, Delaware
For sale is a 1988 extended cab Toyota Pickup. It has a solid axle swap done to it using the 4” kit front and rear from trail gear. The solid axle was rebuilt when the swap was done less then a year ago. The truck has a 3.0 v6 in it with 190,000 miles on it and it runs well. I replaced the timing belt, brake master cylinder and crank seal at the time of the swap as well. Truck has 33” firestone destination AT’s on it with decent tread. The interior is pretty clean, has a kenwood head unit. This truck could easily fit 35’s + I just don’t have the money to afford this stuff right now and will be going to college soon. Stock 4.10 gears, no lockers. Does have the v6 rear end. The frame is solid.
Problems:
-This was a wheeler so the body is rough. Passenger side door is dented in and hard to open from the outside but opens fine from inside.
-Needs the pinion seal replaced in the rear axle, not leaking bad though.
- In 4wd because the angle of the drive shaft is so steep in the front it will rumble when you drive it on the street. Works fine on the trails. Easy fix would be to put in dual cases to make the angle better.
It has a home built front bumper on it, will include a simple black tube rear bumper and fender flares. Will also include a good bed, but paint does not match.
Asking $3200, located in Wilmington, Delaware, Pm me and I can send you some pictures if you are really interested. Feel free to ask questions
Problems:
Peteyg39@hotmail.com
Jun 26, 2015 08:15 AM
