Stock ride hieght measurment
Hello,
I was reading son recomendations from axleike and he was saying to return you suspension to stock ride height after bjs. My question is how do I know if it is still stock height after 13 years and 200kmiles. When you measure is it from the center of the hub to the fender rim? This seems logical as it would give you a true measurement regardless of tire size? I Have tried searching and local dealer(usless).
The exact number isn't critical. You may have sagged a bit, but likely not much.
You are correct, however, on your measurement. You need to measure from something constant, like your hub or rim edge. The hub is the best.
foampile
Dec 18, 2022 01:29 PM
89fourrunner
Feb 17, 2016 06:52 AM
