What frame can i use on 84 ext cab 4x4
Old May 2, 2008 | 01:15 PM
coaldigger's Avatar
I got a 84 4x4 ext cab truck that needs a frame. I was going to fix the frame that was on the truck. But, there's to much rust... Can i use a 88 or ? ext cab truck frame if i cut off the IFS brackets and weld on new spring hangers..Will the cab, bed, and trans line-up with out moving the brackets on a later mode ext cab truck frame...Any help with this will be much appreciated..Thank you..
Old May 2, 2008 | 01:19 PM
DeathCougar's Avatar
you can use anything you want, with enough fab work.
As for direct bolt up without suspension work, it would be 84-85 X-cab only. The 86-88 frames will bolt up the cab and bed just fine, but obviously you will deal with the IFS issue.
Old May 3, 2008 | 09:22 AM
86tuning's Avatar
If it were mine, I'd go with a regular cab frame for the shorter wheelbase, and modify it like the guys at FROR did with their pickup. I'd make a 4' bed by shortening it both at the front and the back.
Sep 4, 2015 09:27 AM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
Nickdigg
Jul 7, 2015 06:04 AM
Steezy96yota
Jul 6, 2015 10:00 AM
elwood73
Jul 5, 2015 07:07 AM
