Built '90 Toyota 4Runner For Sale:V6,Lifted,Lockers,5.29s,35's, Body & Glass Damage
Old Apr 29, 2008 | 08:13 PM
biker1's Avatar
FOR SALE: Built 1990 Toyota 4runner SR5 $5500
THE STORY: This 90 4runner has been my daily driver for the past year and 2
months. I purchased it from JT's 4WD Shop in Washington State in January 0f 2007. The owner of that shop, a differential guru and veteran of the industry, had built the runner up himself and I was really glad to get this sweet rig. I have driven this everyday since then and it drives great and literally goes anywhere! I live at 3500 feet in snow & mud country ( as of today we still have 4 - 5 feet solid of snow on our 800 ft long driveway) and this vehicle has never left me stranded. I have been amazed at the way this thing can climb though the deepest of snows (I personally have driven it over & thru 6 - 8 foot deep snow pack), creep through sticky gooey mud holes and blast up sand dunes to places most quad/atv's wouldn't go.
My wife, daughter and I recently took it on a 8,000 mile road trip down thru mainland Mexico and back up the Baja peninsula. We were loaded with surfboards, camping gear and friends along the way. On the way home we turned 300k on the odometer. The 4runner turned heads wherever we went.
I have also driven it through and over some of the gnarliest passes in British Columbia on dirt and snow roads and trails. To say the least I have really enjoyed the vehicle and hate to be writing this ad. About a month ago I was headed home from a day of skiing, it was night and I hit a patch of iced ruts and brake bumps, overcorrected, hit the bank, drove up onto it and put the 4runner onto its passenger side. I drove it back to town the next day. It drives fine and exactly the same as pre-wreck except for the windows and exterior body damage. The resulting damage was broken windshield, rear window, damaged passenger doors and quarter panels, broken mirror and bent door post. I talked to a local and respected bodyman here and he said he could get it straight and deliver it back to me with dorrs and windows installed and finished with primer for $2k or less. I would have to procure and provide the doors, glass and quarter panels which I found available locally for less than $300. I hate to sell this 4runner but I think that there may be someone who is either a bodyman himself and can get this thing back on the road with ease and little investment or there is someone who wants a professionally built trail rig to bash around and this would fit the bill as is. Or it could be chopped up and a welder/fabricator could have a heyday with a custom tubing cage / roll bar setup and 1/2 doors, fiberglass fenders, etc, etc... Either way this 4runner is built and ready for daily driving, weekend warrior'ng or total trail domination.
VEHICLE SUMMARY:
ENGINE: V6 / 3.0 LITER w/ Rebuilt heads, new head gaskets, runs great,
4x4, 302k
TRANSMISSION: 5 speed , 4H/4L
DRIVELINE GOODIES: Rebuilt driveshafts, Rebuilt axles with Professionally installed 5.29 gears and Detroit lockers w/ all new bearings and seals (Trutrac front, Locrite rear), manual hub conversion, Custom 3rd member
SUSPENSION: IFS Front Pro Comp 4" lift, Rear Toyota Coil Spring Lift w/ Air Bags and w/ minor fender trimming (no body lift)
TIRES and WHEELS: 35"X12.50" Pro Comp Mud Terrain W/ 35% RR, 50% FRNT mounted on Pro Comp Rock Crawler 15x8 Black Rims
COLOR: Red
ADDT'L FEATURESower locks, windows, ac blows but needs refrigerant for cold, 2" Receiver hitch, Floormats, Clarion CD player/Tuner with Boston 6x9 and Sony Xplod door spkrs, Rear passenger heater, Tailgate mounted swing-away w/ used 33x12.5"spare tire, Brand new NGK plugs, Brand New Napa Gold Oil and Filter, Front supplemental lights and rear supplemental backup lights with switches, THULE rack
CONDITION: Overall in great condition except for damage due to rollover onto passenger side, straight body w/ glossy original red paint on driver side, , drives great and starts fine with brand new NGK plugs, K&N Air Filter and Napa Gold Oil and Filter change.
I got an estimate from JT's so I could see exactly what was installed and the cost of parts and labor - it is listed here below:
Estimate
Date
4/1/2008
Estimate #
3997
J.T.'s Parts & Accessories
406 S. Wenatchee Ave
Wenatchee, WA 98801
Project: 90 4RUNNER SR5
Description - Qty - Cost - Total
SUSPENSION: 86-95 TOYOTA PRO COMP 4" FRONT LIFT ONLY (NO
SHOCKS) 799.99
90-95 TOYOTA 4RUNNER REAR 4" LIFT COIL SPRINGS (PR) 159.99
AIRLIFT AIR BAG KIT 4RUNNER COIL 120.00
SHOCKS 4RUNNER W/ 4" LIFT 4 @ 45.00 = 180.00T
INSTALL IFS SUSPENSION LIFT 90 4RUNNER 1,100.00
TIRES/WHEELS:
PROCOMP MT 35 X 12.5 X 15 4 @ 199.99 = 799.96T
Steel wheel 15 X 8 6 on 5.5 3.75 BS Rock Crawler black 4 @ 69.99 = 279.96T
MOUNT / BALANCE TIRES 4 30.00 120.00T
GEARS/LOCKERS / manual hub conversion:
TOYOTA 8" V6 & TURBO 5.29 R&P 1 230.00 230.00T
V6 & T4 TOYOTA MASTER INSTALL KIT 1 210.00 210.00T
V6 & T4 TOYOTA LOCK RIGHT (USES STOCK SIDE GEARS) 1 310.00 310.00T
7.5", 8", & V6 TOYOTA REAR INNER AXLE SEAL 2 7.25 14.50T
7.5" TOY 5.29 R&P 1 260.00 260.00T
7.5" IFS (W V6, TT, OR TRD)(INCL SIDE SEALS) NO SIDE
SHIMS
1 220.00 220.00T
7.5" TOY IFS TRUE TRAC, 50MM JOURNAL 1 475.00 475.00T
CV AXLES 2 149.99 299.98T
AISIN LOCKING HUBS 1 281.00 281.00T
AXLE TUBE FOR MANUAL HUB CONVERSION 1 120.00 120.00T
AMSOIL SYNTHETIC GEAR OIL, 80W-140, BULK OIL BY THE QT 5 11.99 59.95T
U/JOINT TOYOTA TRUCK 2 35.00 70.00T
FR & RR REGEAR 1 980.00 980.00T
Exhaust replacement: materials and labor exhaust 1 150.00 150.00T
ENGINE REPAIR:
rebuilt heads 3.0L toyota v6 2 325.00 650.00T
head gasket set 1 220.00 220.00T
timing belt, accessory belts 1 250.00 250.00T
heads/head gaskets 22 70.00 1,540.00T
oil, coolant, etc 1 150.00 150.00T
GRAND TOTAL FOR ABOVE $10,050.33
NADA VALUE 1990 Toy 4runner SR5 $3,100.00
If you consider that this 4runner has had $10K in mods, NADA is $3K then this runner would cost around $13K (or more considering inflation) to create today. Take 14 months depreciation and wear off and I figure it worth about $8k then subtract the body and glass repair and your at $5500.
Will consider trade for a 2002 or newer Tacoma with or without engine and tranny or a Diesel Mitsubishi Delica or a partial trade plus cash for a quad cab Toyota diesel truck.
I can deliver for gas and transportation costs or vehicle can be picked up in Sandpoint, Idaho. Please let me know if you have any questions.
PRE WRECK Jan '07 PHOTOS:
WINTER WHEELIN' APRIL 07 PHOTOS:
MEXICO JAN 08 PHOTOS:
POST WRECK APRIL 08 PHOTOS:
6th Gear
19
Dec 10, 2019 07:31 AM
vasinvictor
Jan 20, 2016 12:39 PM
YotaLogic
12
Nov 17, 2015 06:27 AM
JaredL
Jun 16, 2015 04:47 PM
