Sponsored by: CARiD
95 T-100 and spray washer...uggh!
Old Apr 19, 2008 | 05:47 AM
neonmasters's Avatar
Ok..As you can tell this is my first post but I've lurked around for awhile. I am the original owner of a stock 95 T-100 extended cab 4x4 with 144k on it. It has never missed a beat......never....awesome truck just like my other 3 Toyota 4x4's ive owned in the past. Ok....I got the hots for a new FJ cruiser and was wanting to clean up my engine at the car wash before I sold it.......After spraying down my engine and driving it home......the next morning my truck is missing and driving like crap. I let it dry out and I'm on my third day and it still is missing badly. I went out last nite in the dark and tried to look for some sparks from my coils and plug wires but couldnt see anything? I got my air compressor and blew out my alternater and around the coil packs? any ideas greatly appreciated..... I think my t-100 sensed that I was going to dump her and she is making me pay......thanks Mark
Old Apr 19, 2008 | 06:54 AM
taandctran's Avatar
pull the spark plugs and clean them up. I did that before. scared me to death.
Old Apr 19, 2008 | 07:16 AM
Dublin's Avatar
Moisture in the distributer cap?
Old Apr 19, 2008 | 08:14 AM
I have the 3400 4 cam engine and all I see are the coils over the 3 spark plugs and wires going across to the other 3 plugs?
Old Apr 19, 2008 | 08:23 AM
taandctran's Avatar
Your engine dosent have a distrbutor. It has coil packs
Old Apr 19, 2008 | 08:36 AM
Thanks taandctran.......I guess I'll change out the plugs and see if that helps..
Old Apr 19, 2008 | 08:58 AM
taandctran's Avatar
U dont have to change them just clean them and ur wire ends too
Old Apr 19, 2008 | 09:23 AM
Pulled off all the coil connections and sprayed with WD-40. Pulled out the plugs and cleaned them up. They looked pretty good.....I dunno?
Old Apr 19, 2008 | 09:49 AM
taandctran's Avatar
What about where the coils connect to the wires i think u have to unscreew it
Old Apr 19, 2008 | 10:31 AM
Where the plug wires that go to the opposite side of the engine and connect to the coil? I'm not sure how they come apart? any ideas? thanks
Old Apr 19, 2008 | 12:08 PM
Ok.......I had some marginal looking plugs so I changed them out....Nothing has changed....My check engine light is still on.....I havent had it read yet to see what faults.....Anyone know how to get the plug wires that go to the opposite side of the engine detached from the coil? thanks
Old Apr 19, 2008 | 12:31 PM
Ok.......I let my truck idle for 10 minutes or so...It was running rough at first....Then it was liike it took a liking to the new plugs and started purring like usual.....I took it for a test drive and it ran like a champ. Not a miss...My check engine light is still on? Does it need to be reset? Thanks to all......I'm a happy guy....I'm worse than a shade tree mechanic....I'm a shade tree with tools with no knowledge to use them.....Thats why I've bought Toyota since 1980. Forums like these are a blessing for a noobie like me.......thanks again
Old Apr 19, 2008 | 12:56 PM
ozziesironmanoffroad's Avatar
just either pull the efi fuse, or disconnect the battery for about an hour. that should reset the light
Old Apr 19, 2008 | 01:08 PM
Thanks.......I took the EFI fuse out with no help......But when I took off the battery terminal loose.....it fixed the light......took a long test drive with no problems......Thanks again to all.....Mark
ashamsuddin
17
Jul 22, 2024 03:59 AM
RobotMoose
Feb 22, 2020 07:44 AM
nvwiggins
13
Jun 16, 2016 03:05 PM
the_supernerd
Oct 1, 2015 09:20 PM
larrys93pickup
Sep 17, 2015 07:05 PM
