89 SASed pickup for sale or trade
Old Apr 15, 2008 | 08:56 AM
joeylead's Avatar
Truck is now gone....
Old Apr 15, 2008 | 09:23 AM
Nughuffer's Avatar
I have a stock 88 22re 4x4 5 spd that i just put new front axles, bearings timing chain, radiator, plugs wires etc.. SR5 gauge swap and rhino lined camper top on? 205k
Old Apr 15, 2008 | 09:46 AM
UKMyers's Avatar
What is the purpose of this reply...? Are you trying to trade sell or what? Please provide more information or start your own thread that abides by the rules of the For Sale section.
Old Apr 15, 2008 | 12:27 PM
Victor's Avatar
Really nice truck but you are too far I think. Good luck tho
Old Apr 15, 2008 | 05:40 PM
joeylead's Avatar
Well since there is interest, let me give the specifics of everything about the truck, just so everyone knows everything:
SAS/Suspension: the sas was done using allpro hardware and an 83 front axle. The main part of it (welding the spring hangars and axel prep) were all done well. However, the original shock towers are utilized. The rear suspension is all leaf and shackle (alcan leafs i believe) no blocks. So basically the suspension needs new shock towers and shocks.
Drivetrain: the engine is at 173k. It starts right up, runs smooth and pulls better than I expected. The truck does not blow any smoke or anything like that. There is nothing that ought not be in the oil (ie moisture) The clutch and tranny work great, the t-case shifts smoothly. The axels are geared to 5.29's and give the tuck better power than I would think. Only the front has a locker (loc right). The exhause hangs a bit low and the truck is loud. It sounds good though. Everyone thinks it is a v6.
Wheels/Tires: the 4 37X13.5 procomp x-terrains are mounted on black steelies and have about 50% tread. The spare is the same tire, almost brand new.
Interior: It could use a good cleaning. The dash is not cracked and in generally good shape. the cloth on the door panels is loose and there is a tear in the drivers seat on the side. The stereo is not worth mentioning and there is no A/C. The heat works well though.
Body: The body is in generally good shape, but a show truck it is not. There is a good amount of pin striping and the tailgate is dented.
The Bad: The only 2 real issues right now (besides leaking front axel seals, but I will include the rebuild kit I have) are: there is a bad steering shimmy from 40-50 mph. My mechanic said it was either tire balance or a bent rim. There is no bump steer or death wobble when driving and hitting a pothole or something. Also, the speedo cable needs either to be lubed or replaced as it squeals.
Basically it is a great truck for the backyard tinkerer to (like me) to have. It runs great and the major work is all done, and most anyone can do the rest to make it whatever they want. That was my reason for buying it, but it just isnt the right time for me. I love the truck and want to keep it, but i figure it doesn't make sense as i dont see myself using it much if at all.
What i am looking for: I should have said this originally. Most likely i am looking at an 89-95 pickup. 4cyl, 4X4, A/C would be great, something in the low 100k miles range. The goal would be to use it as is now and build it up at a later date. A truck like that ought to be worth about as mine. Because it needs some work and the body isnt great, and gained from the SAS regarding value are sort of cancelled out.
Anyway, that everything! I will try to get more pics this weekend.
Old Apr 15, 2008 | 05:49 PM
bigt's Avatar
Location?
bigt's Avatar
In Newyork Dam How Far From Canada
Old Apr 15, 2008 | 07:00 PM
lookmomnobrains's Avatar
hey there. im on long island too. whereabouts are you? id like to come take a look at it. im definetly interested. if you could email a contact phone number to decay220@aol.com id appreciate it! - jamie
Old Apr 17, 2008 | 07:00 AM
yota711's Avatar
you have a PM
Old Apr 17, 2008 | 07:40 AM
fastkevman's Avatar
That looks like a grille and headlights from a 3rd gen 4Runner....looks good, did you do that or buy it that way?
If you did that....did it just fit right in there or did you have to do lots of modifying?
Old Apr 17, 2008 | 10:09 AM
joeylead's Avatar
the truck came this way, it does look really good. It doesnt look like anyhting was modified to make it work.
Old Apr 20, 2008 | 07:03 AM
joeylead's Avatar
Old Apr 28, 2008 | 05:51 AM
joeylead's Avatar
bump...
Old May 3, 2008 | 06:35 PM
joeylead's Avatar
The asking price is now 3800 and i will also consider trade + cash for a 2wd tacoma
Old May 3, 2008 | 06:44 PM
EWAYota's Avatar
Why can't these be closer to me? I'd swap you straight across for my 94 and some cash if needed.
Old May 14, 2008 | 06:40 PM
joeylead's Avatar
well, what do you have? Maybe we can work something out?
Old May 14, 2008 | 06:55 PM
bigt's Avatar
i got a 93 and a 95 trail rig.. if you get this over the border ill give youa ride home
Old May 15, 2008 | 06:24 AM
joeylead's Avatar
I dont have any time for a roadtrip until the summer, so maybe some time in July perhaps!
Old May 15, 2008 | 05:07 PM
bigt's Avatar
LET ME KNOW IM SAVING CASH!!!! fixing my 2 yotas if you wanna trade and I want a pickup!!!
Old May 15, 2008 | 10:28 PM
LIYOTA's Avatar
How have i not seen you or your truck? I thought i was the only person on long island who was into toyotas...
