White smoke at startup
Old Apr 14, 2008 | 09:46 AM
redlegdvldg's Avatar
I just bought and 84 with a 22r in it and is smokes white smoke at start up, the coolant dissappears also when it is running. Head Gasket blown on intake side?
Old Apr 14, 2008 | 10:17 AM
XtraSlow_XtraCab's Avatar
That's what my truck did. Coolant is being burned off inside the exhaust system, thus creating steam. Go smell the white smoke and stick your hand up to it and it should feel humid (if its coolant).
Check your oil cap and dipstick for mixed coolant and oil. You can tell because the oil will begin looking like milk.
Once you've verified that the headgasket is leaking, it is mandatory that you postpone driving the truck. Over time, water finds its way into the cylinders and atop the pistons. What's wrong with this? Well, a 4-stroke motor has a compression stroke, right? Well, water doesn't compress... so something has to give (i.e. connecting rod).
Old Apr 27, 2008 | 12:06 PM
artinge3's Avatar
any guesstimates on how much you could sell a 4runner with a blown head gasket for?
1990, 220,000 kms , lots of new parts 3.0L auto...some rust
Old Apr 27, 2008 | 12:27 PM
NicCantDecide's Avatar
It depends where you're located, but not much. Around here (CA Bay Area) that would probably go for 1500.
Old Apr 27, 2008 | 04:30 PM
rowdy235's Avatar
up here in Oregon it'd go for around 1000, 1500 would be a stretch
Old May 7, 2008 | 02:43 PM
greenhorn's Avatar
check toyota's recall
you may get it done fore free
puddlepirate
Jul 30, 2016 06:29 PM
Ditch Doc
Oct 27, 2015 03:20 PM
dzldust
7
Oct 6, 2015 05:39 AM
1985 4Runner
Sep 30, 2015 10:17 AM
charlie_fong
Sep 27, 2015 10:06 PM
