Anyone have a partsheet list? I broke a front sway bar hanger.
are you talking about the thing hanging in the picture? i have a '98 part sheet that lists that as a "bracket, bushing" and shows part #s as:
Right 48824-35120
Left 48829-35090
the actual stabilizer bushing is 48815-35100 and is the same for both L and R
on further inspection, the parts sheet states it is for '96-'02, that may or may not be the case and these part #s may have been updated since this publishing. hope this helps you out.
Right 48824-35120
Left 48829-35090
You're not going to need any parts. Just some luck and the right swear words! The end that snapped off is a stud mount and most likely it's gone but we can't tell from the pics. The other side is a bolt and you might be able to cut that on to get it out. Once you have the the bushing retainer off, just hammer the old stud all the way out if it's broken off. You can either use a bolt in it's place or tap the old stud hole to use a bolt or try to hold a nut behind it but that will be difficult because of space issues. You'll develop a few new swear words along the way.
Good luck!
Good luck!
Good luck!
Good luck!
Anyone on here have any good places to try and see if they can order me a Lpart # -48829-35090?
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
Jan 30, 2026 01:57 PM
coffey50
Jul 28, 2015 10:55 AM
Vargntucson
Jul 4, 2015 12:15 PM
4881535100, 4882435120, 4882435150, 4882935120, bar, broke, driver, forum, hanger, left, side, sway, toyota
