22re- wierd problem
Old Apr 6, 2008 | 09:22 PM
84 yota ex-cab's Avatar
22re- wierd problem
I have a 22re in a 89 toyota 4wd. When in is cold, if i rev it up, it will idle very erratically. Also, it will have no power until about 3,000 rpm whether or not it is cold. I checked my timing, cleaned injectors and new fuel filter. Could it be a sensor or something?
Old Apr 7, 2008 | 01:17 PM
DCYota's Avatar
Among MANY things, it may be the engine coolant temp. sensor.
http://personal.utulsa.edu/~nathan-buchanan/93fsm/
Old Apr 23, 2008 | 08:36 PM
I also noticed if i pull my foot off the gas a tiny bit while driving, it will act like there is no throttle applied at all, almost like it stalls. it doesn't do it all the time but it has happened quite a bit.
Old Apr 26, 2008 | 08:58 PM
84sr5yoty's Avatar
Have you tried pulling any codes from the computer?
The way it's acting, it sounds like a AFM (air flow meter) is bad. Try testing it out and report back.
Old Apr 26, 2008 | 09:33 PM
abecedarian's Avatar
Saying "when I rev it up, it idles erratically" doesn't mean much.
revving it up is not idling and vice-versa.
Are you saying that after starting the engine when cold it idles fine, but when after revving it up then letting off the throttle it won't idle properly... and when it's warm it won't idle properly at all?
Think you can be a little less vague?
Old Apr 30, 2008 | 02:57 PM
Sorry, if i rev the motor, after i rev it, it will idle erratic. If i don't rev it when its cold, it will idle steadily. It isnt throwing any codes.
Old Apr 30, 2008 | 05:03 PM
Flash319's Avatar
Sounds like your TPS is out of adjustment or no good based on your "Leting off the throttle" comment. This may not account to much for the idle problem though. Jumper your check connector when the engine is warm and see if the idle drops. If not you TPS is out.
Old May 6, 2008 | 09:49 PM
It will idle down with check connector jumped.
SubiKing
Aug 21, 2021 03:57 AM
theking11863
Mar 19, 2016 09:36 PM
Logz808
Jul 26, 2015 07:09 AM
Jonny246
Jul 24, 2015 12:37 PM
kyletbert
Jul 17, 2015 11:39 AM
