Fuel line and fuel return hose question
Both my High pressure fuel line and my fuel return hose were cut when the engine was removed.
I am planning on using the ORS kit and was wondering if I am going to have to replace these two lines with new ones since they are missing the factory connections.
Thanks. I'm not sure how the 3.4 and the 3.0 lines get connected together in the swap so maybe it's not an issue. Just trying to get as many of the details worked out before I dive into this. Of course I suppose it will be self evident what I need to do once the kit is in my hand but I was looking at the lines today and wondering if that is going to be a problem.
This is one way http://www.andrewzook.com/content/view/22/48/1/9/
I went another route and spliced mine together with high pressure couplings. No problems to this point. If I can find out the manufacturer, I'll post it here. Same with the return hose, but it's not high pressure, so it's a bit safer.
Thanks. I was looking at that option earlier. I was just thinking since ORS supplies the line in the kit anyway it would be nice to be able to just bolt it on. I guess I'm going to need another line then. Time to hit the pick n pull. For the high pressure line anyway. For the return line I may just splice it like you did.
Man all these little items are starting to add up. This motor wasn't quite as "complete" as I thought it was.
They cut the line when they pulled mine. I cut mine to match, then used a coupling and proper hose clamps (NOT heater hose style clamps, they won't hold and you'll probably roast your truck to the ground). Not really a big deal. The return hose can be standard fuel hose.
Ya really not interested in roasting my truck. LOL! I'm going to see if I can get a stock uncut line somewhere that won't cost an arm and a leg. Failing that, where did you get the splice and "proper" clamps from?
A stock 3.4 fuel hose will work fine with the conversion - it just needs to be rotated 180* on the fuel rail, so that it points toward the passenger side. The fitting on the end of the hose will thread right on to the fuel supply fitting in the engine bay.
The return hose was just a matter of running a new length of fuel hose from the engine to the return line - simple.
how hard is it to reach this line once the engine is installed? i know on my 3.0 i ended up pulling off almost everything above it. if there's that much work involved with the 3.4, i'm thinking it would be best for me to install a new one before putting in the engine, rather than reusing the old one.
I have more detail on page 3 if you scroll down a bit:
https://www.yotatech.com/forums/f160...85/index3.html
I realize the OP's OEM lines have been cut, but I think I'd scrounge a salvage yard or two first to see what I could dig up. Mind you, if the yards in your area are anything like ours... finding a 3.4 is going to be next to impossible.
Great!
For what it's worth, I had good luck with D&M Recyclers. They're the guys I got my 3.4 from in BC.
http://www.autorecycling.com/
They get e-lockers in from time to time!
TURBOrunnerNM
Jul 22, 2015 11:01 AM
