Check Enging Light/VSC Off/VSC Trac
Old Apr 6, 2008 | 10:03 AM
Mac6135's Avatar
Hey guys,
Driving the '02 SR5 runner on the highway yesterday and all of a sudden my check engine light came on and so did the VSC Off and VSC Trac light.
Everything still seems to be running fine.
I did preform the mod with a switch to turn the VSC off a couple of years ago; however it usually turns the ABS off too (the ABS light will come on). I checked this switch and it is off.
Any ideas what this may be?!!?!?!
Old Apr 6, 2008 | 10:31 AM
DeathCougar's Avatar
Well hows about you pull the code first, then tell us the code and we can advise you further.
Old Apr 6, 2008 | 11:13 AM
Mac6135's Avatar
Yup-sorry! My Bad...
Code P0446 from AutoZone
-'malfunction exists in the electrical circuit for the vent control in the evoprative emission control system.'
Any suggestions or just take it in?
Old Apr 6, 2008 | 09:34 PM
Sounds like the evap canister is having issues. Did you overfill you truck recently or not tighten the gas cap.
Old Apr 7, 2008 | 07:43 AM
cackalak han's Avatar
The VSC/TRAC lights trip by default when the CEL goes off. So whenever the CEL lights up, you will see VSC/TRAC light up with it. The system disables the system as a safety precaution.
Old Apr 7, 2008 | 12:34 PM
Roadrunner's Avatar
I've got the same error code too, I may have not tighten the gas cap all the way during a refill. However, if there is in fact a problem with this system, if I continue to drive the truck until I get my mechanic to check the 4Runner, will that cause any additional problems? Thanks.
Old Apr 7, 2008 | 03:12 PM
crazyquadrider83's Avatar
I am having he same issue's with my 02 Runner! My buddy woeks at Discount Auto, he ran the code & said it was either the mass air flow sensor or the o2 sensor!
Blamalam
Mar 12, 2022 07:34 AM
raptor510
Aug 19, 2015 02:15 PM
129Creepin
Aug 5, 2015 10:12 PM
jimkoz26
Aug 5, 2015 03:15 PM
yourrealdad
Jul 29, 2015 11:08 AM
