Bolt on D-Rings - Good idea???
They'll be as strong as the bolt heads or the material they are attached to.
Either way... there are much stronger ways to attach a shackle point to a bumper. You'll also want to keep the shackle points as close as possible to the bumper mount brackets so load is being transfer to the frame and not just the body of the bumper.
Ultimately, you want to pull on the frame... not the bumper.
Thanks
If you use some grade 8s that are close to diameter of the stock tow hook bolts you should be ok. A backing plate would be a good idea to keep the bolts from distorting or ripping through the bumper. From the photo, the strapping around the loop looks a little on the thin side.
The other problem with the design is that the hoop is not easily removable so that you can hook it through the loop of the snatch strap. Yeah, you can loop the snatch strap through itself but that is less a less than ideal way to use the strap.
Sep 4, 2015 09:27 AM
jon.r
Jul 11, 2015 03:34 PM
