sorry if its a n00b question
Old Apr 3, 2008 | 06:30 AM
87pickup's Avatar
in all reality how much would it cost to put a chevy 350 with all the neseccary adaptors and add-ons into my 87 pickup? i plan on getting 35's with at least another 6 inches of lift so i could use a lil more power than my 4 banger.
Old Apr 3, 2008 | 06:32 AM
sleaz22xx's Avatar
check out the engine swap section, there is a ton of info in there
Old Apr 3, 2008 | 07:08 AM
07sbock's Avatar
Probably 1500+ bucks to do it right.
Old Apr 3, 2008 | 07:12 AM
MonsterMaxx's Avatar
That depends on if you want it done right and with a driveline which will handle the extra power, or if you just want to shove a 350 in there for bragging rights.
A good 350 will have more power than the Toy driveline will handle. To make it reliable you will need to replace the whole driveline. (you may be able to use the toy tcase if you have the gear to gear one - based on the year you probably do have.)
What you may want to consider is a swap like the 3.4. Cost wise you'd spend about the same, but it's lighter and won't be nearly as hard on the drivetrain. Figure $4k
Old Apr 3, 2008 | 08:09 AM
norcalsvx's Avatar
check NWOR for the swap kit or ORS for the 3.4 swap stuff
Old Apr 3, 2008 | 08:43 AM
Yota Tony's Avatar
Depends on so many factors it's hard to give a good estimate.
I'd say $1000-10k depending on the deals you get, the parts you use, the parts you break, etc.
lectric80
Aug 11, 2015 12:02 AM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
TJWilly
Jul 31, 2015 02:05 PM
4Runnin2000
Jul 29, 2015 06:09 PM
