93-98 T100s All T100 trucks
Back Up Lights?
Old Apr 1, 2008 | 12:38 PM
funnyguy44444's Avatar
Back Up Lights?
My back up lights do not work. So my question is; where do the wires for the lights hook into the transmission? I think they might just be unplugged.
Thanks.
Old Apr 1, 2008 | 01:43 PM
BamZipPow's Avatar
Do you have an auto trans? If you do, did you check the "Gauge" 10A fuse and the back-up light relay (it's a square one) located in the interior fuse box? Are you sure you checked both light bulbs and run current through them or did a continuity check? Did you check the harness? Did you check the backup switch?
Old Apr 2, 2008 | 07:49 PM
Its a manual not auto. The bulbs are good. All the fuses are fine. Haven't checked the harness or backup switch cuz i don't know where they are. That's what i was hoping to find out, what components are they hooked to and where those components are.
Old Apr 3, 2008 | 05:54 AM
BamZipPow's Avatar
It should be a 2 wire switch located on the side of the transmission.
The switch is a threaded type with a hex body.
Charecter1
Nov 6, 2023 10:08 AM
ashersullivan88yota
Jan 18, 2022 05:37 PM
Jun 1, 2021 01:51 PM
colinmil
Jul 6, 2015 04:03 PM
elwood73
Jul 5, 2015 07:07 AM
