anyone grease spindle bushings as maintenance?
It seems extreme to me too. If you had that done at a dealership, you'd be looking at several hundred dollars. And, in the end, you're really only protecting about $90 worth of parts.
I would just leave them alone and replace them if they go bad. If you've got the right tools, it can be a do it yourself job. I replaced mine recently, but had access to a shop with a lift and hydraulic press.
From my research, I found that the bushings Toyota used are prone to failure. Dealerships have begun replacing them with a needle bearing/thrust bushing combo that they claim lasts longer. I did a write up on my install if you want to take a look at it:
Steering Spindle Bushing Replacement
kawazx636
Oct 6, 2021 03:03 PM
live4soccer7
May 11, 2016 06:52 PM
punks_is_4x4
Feb 26, 2016 04:29 PM
Truckwithoutaname
Oct 3, 2015 03:41 PM
