Can't remove CrankShaft Pulley bolt
I am replacing my 96 4runner 4WD V6 3.4l timing belt. And I can't remove crankshaft Pulley bolt. I used air gun(500lb torque) and doesn't move a bit.
Anyone has any idea to remove it without buying a special tool for it?
Thanks
Thanks
Another way people do it is crank the motor but be sure you unplug the ignitor before hand and place a breaker bar to the frame and it can break the bolt loose. I dont much like the idea but it works for some people.
See this also
https://www.yotatech.com/forums/f116...y-bolt-130240/
See this also
X2 on using the starter. I used a C-clamp to hold the breaker bar to the frame. Just bump the starter a couple times and it comes right off. I know it sounds scary but it works great. It would be much easier than removing the oil pan and wedging wood between the block and crankshaft.
I am not a fan of shade tree wrenching but I fought that dang crank bolt for 2 hours!! Heating, tapping, then big daddy impacting. Around and around I whent for 2 hours. On ONE BOLT! Then I found this thread. Whent out and gave it a try. Bang the bolt was loose in a second. I could have been done with my timing belt job had I done this from the start. Also do unplug the coils to be safe.
Cheers
Cheers
Blamalam
Mar 12, 2022 07:34 AM
TJWilly
Jul 31, 2015 02:05 PM
dinks07
Jul 15, 2015 05:34 PM
