Changing PCV valve - came across a couple of issues
First time changing PCV valve - just finding it was half the battle (I think).
When I tried to get the grommet out, it came out in pieces. I got most of it out (98%), but I can't be sure a few crumbs didn't break off and fall in. Is this something I should be concerned about?
Also, to get to the valve, I ended up removing the piece that the other end of the PCV hose goes to. Don't know what its called, but its held on with two nuts and is a tube with a 90º bend that runs into the plenum. The gasket on this just crumbled away. Can I use something like FIPG for this or should I just get that gasket? If so, what is that part that the gasket is on called?
Thanks!!!
Thanks!!!
Yep Mic, I do mean that. Thanks for the pic, didn't feel like going up to get the camera at the time. And I removed it because this was the simplest way I could figure to get to that PCV valve. And it was simple getting it off, just not sure about putting it back on yet.
Anyway, that part is just called a ventilation tube, the hose is a ventilation hose and go figure, the gasket is a ventilation gasket. Part # 12255-65010 and the hose is 12261-65010 if it helps anyone in the future.
Now, that damn $3 gasket is on backorder and isn't expected in for about a week. The closest dealer to have one in stock is in Montana, and thats a bit too much of a drive from Cali.
Soooooooo, what can I do to improvise on this for a week or until the next time I remove this tube. This was a plastic type gasket, so, would one of those generic cut-to-size rubber or cork type gaskets work? Don't want to mess with liquid gasket as that would make too much of a mess cleaning it up.
I don't need to get it going, but I'd like to as I'm doing a tune up and changing fluids and I'd like to drive and move it as I go.
Thanks!!!
Thanks!!!
