alarm install quick central locking question
hey,
well i am doing alarm/remote start install on my 94 4runner. i did few installs before but not in a while. and to help things the alarm manual is writen in very poor english.
anyways 4runner wirring diagrams list:
power door lock
power door unlock
door triger
all above wires listed as negative
so the dumb question is do i use positive trigered diagram for the alarm. (+12v, lock, unlock)
also i only need to use lock/unlock wires not the door trigger, right?
p.s. just remembered my car is 5 speed so i will need to bypass clutch switch. can i just connect clutch cancel switch wires or do i need to get the switch by the clutch pedal
thanks guys
thanks dz
power door lock
power door unlock
door triger
thanks guys
thanks dz
usually on the 5-wire locking systems, both lock and unlock wires are held at ground, and one or the other is taken up to +12V to spin the motor. the wire that goes high controls which way the motor spins. i don't know exactly what you're asking, honestly, but maybe that'll help.
does your alarm put out a +12V pulse on its locking wires when you hit the button? if so, just tap into the wires given in a wiring diagram you grab off the interweb somewhere, i believe.
on the 94 you need your alarm to output a negative signal. both wires are in your harness coming from the door. double pulse to open the pasenger side. if you need better tech notes try www.the12volt.com. Use a relay to connect the two wires at the clutch switch to bypass the clutch. i really hope you are installing a starter designed for a manual vehicle.....or else you are dumb and are going to kill children in school yards or parks.....
jasonty
41
Dec 23, 2018 01:00 PM
rushw
Jul 18, 2015 01:46 PM
