Suggestions...where's this leak in these pics
92 3VZE Manual 4X4
Hey guys, can anyone help me determing where these leaks are coming from? I seem to have a small oil leak up on the passenger side near where the clutch enters the transmission. I replaced the HG in the summer, and at that time had an issue with the clutch where it just fell to the floor, I had to bleed the clutch to get it firm again. Should I be replacing something in that area.
I've also noticed a small leak/ooze from the rear driver shaft where it meets the diff. How does it look in the pic? Anything to be worried about here? Typical for a 15 year old truck?
Thanks guys
Steve
Thanks guys
Steve
are yor valve cover gaskets leaking? Check those. The rear one is called the Companion Seal, very easy to replace. However the valve cover gaskets are a pain in the butt since you ahve to take off the intake plenum.
94 Newbie
Aug 6, 2015 10:33 AM
itzmywife's
Jul 25, 2015 04:55 PM
Avenged
Jul 9, 2015 07:55 AM
