Is There a differance between front drive Shafts on ABS and Non-ABS equiped 4Runners?
I was thinking of getting this drive shaft as a spare
http://tinyurl.com/2ywbsy
But in the description it says its fits
1996 1997 1998 1999 2000 2001 2002 , 4 Runner , without ABS
I cant see why it would be different, any thoughts?
the speed sensor is a geared ring inside the knuckle assembly. non abs vehicles just have a spacer where the ABS ring would reside. shouldnt matter on the axles.
the only difference as mentioned, is add axles vs manual hub axles. ALL 96+ 4runners have ADD from the factory.
6th Gear
19
Dec 10, 2019 07:31 AM
Mr.Black
Jun 21, 2015 10:17 AM
2000, 4runner, abs, anti, axel, brakes, difference, diffrecence, drive, driveshafts, knuckle, lock, pictures, shaft, tundra
You should be good to go.
