93 3VZ-E Clogged Water Bypass No. 4
Noticed some coolant corrosion around that tucked away water bypass no. 4 hose where it connects to the intake on my 93 3VZ-E. Pulled off the hose and found that both the hose and the flange (or whatever it's called) to the intake are completely clogged with, what looks like, chunks of metallic copper-reddish rust colored material. Clogged solid. Took off the hose and cut it open to reveal what really looks like a torn up piece of gasket or something like that completely clogging the hose, right up at the intake end of the hose. The "gasket chunk" was black with little red, hair-like, pieces of red metallic substance. Dont know if this really is a chunk of something that came loose or if sludge+rust+time = a chunk like that. No idea about the red metallic thread pieces. Looks like the kind of thing you might find inside a hose, but cutting this one open shows nothing of the sort. The reinforcement on this hose is simple whitish cord, didn't see any metal at all.
The pics I took aren't clear enough to really show any of the good detail. Will try to take more and post if necessary, but thought I'd throw this out there and see if anyone has an idea. I don't see any problem at the throttle body end of that hose, and the no.5 water bypass looks clean and fine. What in the world could have gotten in there? My only idea so far is a rusted water pump spewing bits of material into the stream. Pulled it off and sure enough the blades are very rusted. Don't know which way the stream goes through that water bypass though. Hell I didn't even realize it was there until I pulled the throttle, which looks all good far as I can tell. The end of this bypass hose that fits on the throttle looks nice and clean, no signs of trouble until you look at the end that goes to the intake.
Wondering if I should flush the system real good or let it be? I'm replacing the no.4 water bypass hose for $8, and i've cleaned that flange out the best i can by scraping stuff up and out with a tiny flathead. I'm betting something else needs attention but no idea what. Unless someone has a better idea, I will bolt her all back up and see what happens.
1993 4Runner 2WD V6 SR5 3VZ-E @188k. All stock. Headgasket blown 3 times in the last 10 years. Probably blown again, hence why im tearing her up myself now.
Have you owned it long? Maybe the previous owner used some radiator stop leak crap in it. Since that hose is one of the highest points in the cooling system its a likely place for air pockets to form and those stop leak products react with air form clumps.
BTW, I have totally bypassed my throttle body, the coolant hose goes around it now, because I didn't see the need to dump extra heat into the intake.
This drawing should help with that:
http://personal.utulsa.edu/~nathan-b...05descript.pdf
Sure go ahead and flush it real good, can't hurt.
Thanks for the clue. That's a good idea about the high point collecting some additive junk. With the flow going toward the throttle, this acumulation of crap at the slightly higher manifold side of the hose could support that idea.
I've owned the truck since 95 @ 50k, but the engine has had serious work re: headgaskets 3 times, all with what turns out (now that im a little wiser) to be shoddy work. Can't really trust anything in there now, and I'm sure glad yotatech has gotten my back for the last few years of maintaining it myself.
I'll give it a good flush and see what comes out. Thanks for the advice!
next time you are tempted to dump some snake oil into your truck, think of this..
also pulled this high-performance water pump. make me an offer!
Wow, I changed out my waterpump during my rebuild, and my guess is that the old one had all of the 4runner's 150,00 miles on it. But there was NO discoloration of any kind in there. Looked clean as a whistle, but I changed it for my peace of mind anyway, hoping to avoid opening up the front end again ni a few hundred or thousand miles.
note that, before finding that clogged water bypass, the clue for this was tiny rusty metal shavings sticking to the sides of the coolant reservoir. the coolant itself was nice and clean, as even with a few leaks, the level was staying pretty constant.
the1998sr5
15
Jul 14, 2020 08:35 PM
pyramid
Jul 29, 2015 06:53 AM
